De-Esser settings? - 2 second voice file attached
boonman
Post by boonman » Wed Jan 21, 2015 10:17 pm
Voice is full of a lot of ssssssssssssssssssssss
Attached is a 2 second (non-processed) mp3 file. This is direct from my mic.
I need a de-esser, but don't have much experience. Have been experimenting with "DeEsser.ny" a bit.
Anyone out there want to checkout this file and see if you can impress us with your audio wizardry??
e.g. i'd really love to know which settings (plugin) I can use to fix my voice.
:( Have been playing with so many VSTs and stuff but not getting anywhere ; (
Thanks!
shorter-0.mp3
(37.14 KiB) Downloaded 232 times
Re: De-Esser settings? - 2 second voice file attached
Post by kozikowski » Wed Jan 21, 2015 11:10 pm
That's because you don't have "essing." You just have a really bright microphone, and you should try to solve this at the voice/microphone stage, because fixing it in Audacity in awkward and never sounds quite perfect.
First thing I did was Analyze > Spectrum and I found an artificial "haystack" or boost starting around 3000 and ending around 11,000. You can drag the analysis window larger to make it give you more information (attach 1). I figured out the approximate sizes of the haystack, just by looking. No fancy tools. About 12dB tall, about 3000 to about 12000.
Then I ran Effect > Equalization and created a reverse haystack (attach).
When I applied the correction, most of the brightness went away leaving a natural sounding voice. If it's still too bright, you can make the equalization deeper (top to bottom). If you want, I'll try to remember how to export the curve so you won't have to make it yourself.
Screen Shot 2015-01-21 at 14.57.11.png (14.97 KiB) Viewed 3561 times
Screen Shot 2015-01-21 at 14.59.17.png (59.45 KiB) Viewed 3561 times
shorter-0De-Essed.wav
(202.54 KiB) Downloaded 112 times
Post by kozikowski » Wed Jan 21, 2015 11:16 pm
Real "essing" is when the sound crashes whenever you hit SSS. It actually turns into a different sound like listening to a military air traffic controller crashy voice as an extreme example. A De-Esser tries to recognize that damage, suck out the crash sound and substitute what it thinks your voice would have normally sounded like. Yes, it's a bit of guesswork and it's never perfect, that's why it's good to produce a clean track right at the top.
boonman
Post by boonman » Wed Jan 21, 2015 11:27 pm
Thanks man
i'm using this little guy:
http://www.samsontech.com/samson/produc ... nes/gomic/
I guess it's time to get a better mic, and probably an Audio Interface.
Basically, I need to record directly into Camtasia Screen Recorder. And then edit in Camtasia Studio. This is of course not a high-end media editor. (e.g. No post-processing or virtual instruments.)
(In my job I just do lots of screen recordings.)
So it's important that my audio sounds good before it actually gets to the computer. e.g. it's important that it doesn't need any post-processing.
I have had the http://www.bluemic.com/yeti/ previously and was accused of having to much Sssss with that one too.
Can you (or anyone) recommend a good mic (and or audio interface) for direct input into my laptop?
I was looking at this one for the audio interface because it has built in de-esser http://www.amazon.com/dp/B00IMN8U72
Would prefer to spend under 300
Thanks so much!
Post by kozikowski » Wed Jan 21, 2015 11:44 pm
We have two conflicting ideas. Anything with USB in the title generally means that the sound is fixed once it leaves the microphone. All the sound shaping, amplification, noise compensation, etc, etc, is handled in the head of the microphone (the analog part) and that's the way it is from that way forward.
However, I've never seen a microphone with that much of a blatant haystack seemingly all by itself in the microphone personality. There's no way that would ever sound natural in a performance.
Scene shifts to:
A second microphone that also appears to be too bright and sharp. Now it's different. A Yeti is not a terrible microphone and that points to Windows doing something to "help you." It is Windows, right? Macs tend to not have these kinds of problems.
So. Dig in the Windows setups and see if it isn't running something like a "Vocal Clarity Filter" (I'm making that up) or some special effect. We know Windows has Advanced Services what can try to remove noise from your voice while you speak like a cellphone does. This can improve communications or conferencing. However, Windows Enhanced Services hates music.....
See what you turn up. This sharp, piercing effect is not normal.
Post by kozikowski » Wed Jan 21, 2015 11:58 pm
I'm not horrified you're using that little microphone. I've done temporary tracks (carefully) with the little microphone in my laptop and have used other microphones "against-type" when I needed to. I just didn't tell anybody what I was doing.
boonman
Post by boonman » Thu Jan 22, 2015 12:07 am
Thanks
Both mics were USB only.
The Samson mic is just using generic audio drivers. No effects. Just recording direct into Camtasia or Audacity. Gain is the only setting I can alter -- I leave it at 25%
I have some sound foam behind it, and a generic pop filter.
It might just be the way I talk >.<
I suppose my next mic will be non-usb -- and plug into an audio interface (or perhaps a channel first...). So what I need is a solution to get good narration audio--before the signal gets to Camtasia.
(I do software tutorials--so basically just a flat voice talking about database apps)
Trebor
Post by Trebor » Thu Jan 22, 2015 1:08 am
boonman wrote:I need a de-esser, but don't have much experience. Have been experimenting with "DeEsser.ny" a bit.
Attachments shorter-0.mp3 (37.14 KiB)
Spitfish VST gets rid of most of the excessive sibilance, then a notch-filter to get rid of the hot-spots in the sibilance ( which sound like someone whistling through gaps in their teeth )...
original - spitfish - then notched.wav
(803.11 KiB) Downloaded 127 times
spectrogram of ,original - spitfish - then notched.png (293.72 KiB) Viewed 3556 times
Audacity's spectrogram view is demonstrated on this YouTube ... http://youtu.be/7WYw3qoTdU4?t=28s
