Backing vocals
Hallo
Backing vocals
Post by Hallo » Sun Nov 02, 2014 5:19 pm
Hi I've just discovered Audacity. What I need is the backing vocals of the song Rolling In The Deep by Adele for my keyboard. Now I have a karaoke version on youtube (WAV) of the song and I'm wondering if I can remove the instrumental part through audacity so I keep on backing vocals. if possible, how do I do that? I've tried everything from the videos on youtube but it did not work.
Trebor
Re: Backing vocals
Post by Trebor » Sun Nov 02, 2014 6:48 pm
Hallo wrote:... I have a karaoke version on youtube (WAV) of the song and I'm wondering if I can remove the instrumental part through audacity so I keep on backing vocals. if possible, how do I do that? I've tried everything from the videos on youtube but it did not work.
Isolating parts is only possible in some cases ...
audacityteam.org wrote:... This page describes techniques which, on some stereo tracks, may allow you to remove or isolate vocals (or other parts of a recording) from the rest ...
http://manual.audacityteam.org/o/man/tu ... ation.html
There is a free plugin called Kn0ck0ut which will spectrally subtract one track from another ...
kvraudio.com wrote:Kn0ck0ut takes two mono 44.1KHz inputs and spectrally subtracts one from the other. It can be used to help create 'acapellas' - to extract vocals from a track - if an instrumental version (or section) of the track is available.
http://www.kvraudio.com/product/kn0ck0ut-by-st3pan0va
but even when Kn0ck0ut works at its best it generates digital artifacts. :cry:
[ Kn0ck0ut demo ... http://youtu.be/O4UZmlul0sQ?t=40s , an easy case though ].
Hallo
Re: Backing vocals
Post by Hallo » Sun Nov 02, 2014 8:44 pm
The information in the link http: //manual.audacityteam.org/o/man/tutorial_vocal_removal_and_isolation.html I've already tried these options with the videos on youtube. But does not work unfortunately. Maybe I might use the wrong music file? I would really like to know what I'am doing wrong. :?:
Sorry but the link http://www.kvraudio.com/product/kn0ck0ut-by-st3pan0va is not working on my computer.
Re: Backing vocals
Post by Gale Andrews » Mon Nov 03, 2014 9:43 am
Hallo wrote:The information in the link http: //manual.audacityteam.org/o/man/tutorial_vocal_removal_and_isolation.html I've already tried these options with the videos on youtube. But does not work unfortunately. Maybe I might use the wrong music file? I would really like to know what I'am doing wrong. :?:
What you are doing wrong is missing the point ;) . The point is that unless you have the tracks for each part that went into the mix there is absolutely no guarantee you can remove or isolate the parts.
Hallo wrote:Sorry but the link http://www.kvraudio.com/product/kn0ck0ut-by-st3pan0va is not working on my computer.
The VST version of Kn0ck0ut is no longer made. Only the LV2 version for Linux is still being developed. There is an archive copy of Kn0ck0ut at http://web.archive.org/web/201309291145 ... 0ck0ut.zip.
