so this is what I didI used Audacity to split the right and left tracks into different files (working with 4 total files), combined the right and left channels of both into single right and left files (working with 2 total files) and then took those two and recombined them into a single two channel track. Perhaps a little more work than necessary, but I wanted to make sure nothing went wrong. You might be able to get away with throwing both files in there and hitting export, or whatever the command is in Audition. Because what goes through each channel is important in these files I went out of my way to make sure nothing could go wrong. Make sure you convert both files to WAV or FLAC before you start and export as WAV or FLAC to prevent the audio quality from degrading, which will absolutely hurt your results.
- have both files open in audacity
- split the two files
- sort both single "left channel" files together and same for both single "right channel" files
- merge both single "left channel" files into stereo track and do the same for both single "right channel" files « unsure if this is what is meant
- export to wav
Could someone tell me if I have done so correctly, I am a huge noob. Before I posted this question I have read on the wiki and watched some youtube videos. However I still feel unsure.
Thanks
