A De-essing Filter to remove sibilance
RetroRemix
Post by RetroRemix » Fri Sep 12, 2014 9:04 pm
I once used the CoolEdit software and a helpful person designed a De-Essing filter which I saved into the program to remove the excessive sibilance that gives that horrible lisping to some vinyl recordings.
I'd love a similar filter to be part of the Effects menu in Audacity. With a sliding control from weak/mild to strong/severe.
I'm using OS X 10.9.4 so Digitalfish plug-ins don't work. I want something that works with modern Apple computers.
Re: A De-essing Filter to remove sibilance
Post by kozikowski » Fri Sep 12, 2014 10:07 pm
Post by kozikowski » Fri Sep 12, 2014 10:09 pm
RetroRemix
Post by RetroRemix » Fri Sep 12, 2014 11:31 pm
Thanks so much for this.
I'm not sure what i need to adjust when I open it, or do I leave the default settings?
Thanks again :)
Post by kozikowski » Sat Sep 13, 2014 5:14 am
You open the work on your computer with the high quality sound system and adjust the settings so it sounds natural. I've only used the de-esser once and the default settings seem to work. I have no feel for what the controls do.
You thought the performance was harsh and sibilant, so tune the tools so it stops doing that. The de-esser isn't one of the normally included tools, so it doesn't have neat, orderly instructions.
I don't know that I ever had that experience. Are you trying to transfer vinyl without an RIAA equalizer? Or is someone doing transfers with a bad or misadjusted stylus? Is this a USB Turntable, by any chance?
Trebor
Post by Trebor » Sat Sep 13, 2014 8:58 am
RetroRemix wrote:I'm using OS X 10.9.4 so Digitalfish plug-ins don't work. I want something that works with modern Apple computers.
Paul-L's De-Esser is also a Nyquist plugin so works cross-platform, it's available here ... http://forum.audacityteam.org/viewtopic ... 8&p=245549
It's the best de-esser I've used, better than SpitFish , ( also it's not restricted to sibilant frequencies so can be used elsewhere on the audio spectrum : it's a multiband compressor in disguise ).
RetroRemix
Post by RetroRemix » Sat Sep 13, 2014 1:44 pm
kozikowski wrote: I don't know that I ever had that experience. Are you trying to transfer vinyl without an RIAA equalizer? Or is someone doing transfers with a bad or misadjusted stylus? Is this a USB Turntable, by any chance?
Hi Koz.
I sometimes find it with vinyl that has been badly recorded/mastered (often from small independent record labels who put out 12" singles in the 80s and 90s) and with some other people's efforts at recording vinyl, which they then send to me to clean up.
I've come across quite a few examples of sibilance; it's quite common on vinyl.
Paul L
Post by Paul L » Sun Sep 14, 2014 2:49 pm
Hello RetroRemix,
koz and Trebor have both pointed you to my plug-in. Trebor's link includes more explanation from me of the settings.
I will gladly answer questions.
