USB Microphone malfunction
I have a USB Microphone which I use mainly with Skype but since installing Audacity and a SoundLab USB turntable I cannot use it. How can I use both Audacity and my microphone
I am running Windows Vista Home Premium.
Re: USB Microphone malfunction
Just use one at a time. Either have the turntable plugged in, or the microphone, but not both.
You may need to reboot.
Thanks stevethefiddle that works although it is a bit of a pain in the neck.
If it is difficult to physically get to the USB ports, you can probably configure the devices to work through Vista's Control Panel (though that is probably just as much of a pain in the neck)
http://audacityteam.org/wiki/index.php? ... ng_devices
