Level the total volume of a file?
leebbaker
Post by leebbaker » Sun Aug 10, 2014 7:35 pm
Can and how do I level the total volume of the total file without doing small samples over and over?
New to this... Lee
Re: Level the total volume of a file?
Post by Gale Andrews » Mon Aug 11, 2014 1:53 pm
You can try Effect > Leveler... which is easy to use but you will only get a small amount of leveling before you start to hear distortion.
Otherwise try Effect > Compressor... or you can try a third-party compressor plug-in (see http://wiki.audacityteam.org/wiki/Compr ... lternative).
