PESQ Voice Quality Measurement
ramu
Post by ramu » Thu Jul 03, 2014 9:59 am
hello friends i am Ramu i have been searching for PESQ document for voice quality measurement ,i want to know how the algorithm works ,in that how level alignment and time alignment is done and how perception will be done can you please suggest me document which i have to read to know PESQ
Re: PESQ Voice Quality Measurement
Post by Gale Andrews » Thu Jul 03, 2014 10:23 am
Did you try a search engine: http://tinyurl.com/m4otxpa ?
ramu
Post by ramu » Fri Jul 04, 2014 7:32 am
i searched like what you given but i want to know the things how it does level alignment ,time alignment and perception works how they work practically please share documents... :D
Post by Gale Andrews » Fri Jul 04, 2014 9:23 am
ramu wrote:i searched like what you given but i want to know the things how it does level alignment ,time alignment and perception works how they work practically please share documents... :D
Audacity does not use PESQ. There is no reason we would have detailed knowledge about PESQ (see the title of this Forum).
Try asking on the support address of the manufacturer of the algorithm: http://www.opticom.de/contact/address.php .
