plugin that allows you to modify milliseconds from a second example: add damage to 50-500 milliseconds every second. The damage can be anything.
Haven't seen any plugin like that.
MatthewC1000
Re: plugin that allows you to modify milliseconds from a sec
Run this code in the "Nyquist Prompt" effect to create a 50 ms burst of noise every 1 second:
Code: Select all
(setq damage-length 0.05)
(setq amount 0.5)
(setf damage (abs-env (sum (s-rest 1)(noise damage-length))))
(setq dtable (maketable damage))
(defun add-damage (sig)
(sum sig (mult amount (hzosc 1 dtable))))
(multichan-expand #'add-damage s)
MatthewC1000
whats the command for silence...
Try this:
For more information about Nyquist scripts, see: http://wiki.audacityteam.org/wiki/Nyqui ... _Reference
For discussion about Nyquist programming and Nyquist plug-ins, we have a forum board here: http://forum.audacityteam.org/viewforum.php?f=39
Code: Select all
(setf damage (abs-env (pwlv 0 damage-length 0 damage-length 1 1 1)))
(mult s (hzosc 1 dtable))
