How to handle this ?
VincentYann
Post by VincentYann » Tue Jun 03, 2014 8:56 pm
Hello everyone,
thank you audacity and the forumers.
Helping process please. After recording session with a H1 Handy Recorder, one track with many chapters, I don't find access to work with it on Audacity.
It appears on the Audacity track, but trying to make cut and montage, it appear that message:
" Error while opening sound device. Please check the input device settings and the project sample rate."
I don't know what to do, don't know yet those words and their applications.
Thank you!
Vincent
Re: How to handle this ?
Post by steve » Tue Jun 03, 2014 9:11 pm
VincentYann wrote:" Error while opening sound device. Please check the input device settings and the project sample rate."
That means that Audacity is unable to access the sound card that it is currently set to use.
Click on "Help > Audio Device Info", wait a moment for the information to appear, then copy and paste the information into your reply.
Also:
What settings do you currently have set in the device toolbar?
How do you listen to sounds on the computer? (example, headphones plugged into the headphone socket on the side of my laptop PC).
What operating system are you using? (Example: Windows 7 Home edition)
Which version of Audacity are you using? (Example: Audacity 2.0.5 - see "Help > About Audacity" for the exact version number)
VincentYann
Post by VincentYann » Wed Jun 04, 2014 9:30 am
Hello,
well thank you !
here are the infos :
Code: Select all
Default capture device number: -1
Default playback device number: 1
Device ID: 0
Device name: Mappeur de sons Microsoft - Output
Host name: MME
Input channels: 0
Output channels: 2
Low Input Latency: 0,200000
Low Output Latency: 0,200000
High Input Latency: 0,400000
High Output Latency: 0,400000
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    192000
Device ID: 1
Device name: Haut-parleur/Ecouteurs (Realtek
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    192000
Device ID: 2
Device name: Périphérique audio principal
Host name: MME
Input channels: 0
Output channels: 2
Low Input Latency: 0,000000
Low Output Latency: 0,000000
High Input Latency: 0,000000
High Output Latency: 0,000000
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    192000
Device ID: 3
Device name: Haut-parleur/Ecouteurs (Realtek High Definition Audio)
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    192000
No capture device found.
Selected playback device: 1 - Haut-parleur/Ecouteurs (Realtek
Cannot check mutual sample rates without both devices.
For the device tool bar, it is written : MME - Haut-parleur/Ecouteurs (Realtek) - the two other case are empty.
Headphones connected on usb laptop.
Windows 7 edition familiale premium
Audacity 2.0.2.
recorded sessions on H1 Zoom.
Thank you!
Reason: added code tags for readability
Post by steve » Wed Jun 04, 2014 5:13 pm
The problem is that your computer is reporting that there is no capture (recording) device available.
Even if you're not recording, Audacity requires a fully functional audio device (playback and recording).
Go into the Windows Sound Control Panel and enable an input device - it doesn't matter which one (unless you actually want to record something) as long as there is one.
VincentYann
Post by VincentYann » Wed Jun 04, 2014 6:07 pm
Merci, j'ai été sur le lien que vous avez fourni, mais les explications sont en anglais, et dès la première ligne je ne vois pas, System Tray, Control Panel, je ne sais pas ce que c'est,
pouvez-vous m'aider?
Post by steve » Wed Jun 04, 2014 6:37 pm
Sory, I don't speak French.
Does this help? http://tinyurl.com/mlkpnzh
