Creating a voice-only-version doesn't work
max.wenzel.kk
Post by max.wenzel.kk » Fri May 09, 2014 7:44 pm
Hi everyone,
I have problems with creating a voice-only-version of a song via using the instrumental version. Which means, I imported the version with voice and the instrumental version, I exactly aligned the both tracks, I amplified both tracks to maximum amplitude, I inverted the Instrumental track, I selected both tracks and made "Mix & Render". But the result is the opposite of what I want to have: The instrumentals are louder than before and that's everything which changed. If I made some errors I don't recognized, then please watch my video at https://www.youtube.com/watch?v=BbtoV5g6nfU where I screen-recorded that all. I have this problem not only with the song I used in the video, I have the same problem with every song.
Can someone help me?
Thanks in advance,
max.wenzel.kk
Re: Creating a voice-only-version doesn't work
Post by Gale Andrews » Fri May 09, 2014 11:20 pm
See http://manual.audacityteam.org/o/man/tu ... _Isolation . For your method to work the instrumentals must be identical in both tracks. They won't be if you pulled arbitrary files from the internet. Lossy formats like MP3 won't help.
