Itunes Pitch Change on Intel MacBook
redbeard
Post by redbeard » Wed Dec 17, 2008 2:32 pm
Hello.
I am attempting to change the pitch of a tune I recorded in iTunes. I downloaded Audacity 1.2.5/6. I believe I saved the file into Audacity and through the effects lowered the pitch, but I do not know how to check this. Also, I need to know how to load the finished file back into iTunes so I can then create a CD.
Thanks,
Redbeard
waxcylinder
Re: Itunes Pitch Change on Intel MacBook
Post by waxcylinder » Wed Dec 17, 2008 4:26 pm
redbeard wrote: Also, I need to know how to load the finished file back into iTunes so I can then create a CD.
Thanks,
Redbeard
Sorry can't answer the pitch question - but try this page in the Wiki for your secondd qn.: http://audacityteam.org/wiki/index.php? ... s_and_iPod
