Gale Andrews wrote:KenZakreski wrote:Like most other Canadian Community Radio Stations we support audacity for building radio shows.
Thanks for your support, Ken.
KenZakreski wrote:When I build my radio show I drag the audio tracks into Audacity, the meta data seems to come with it. The name of the song goes to the track title in Audacity.
I would like the meta data from each song to stay in the final audio file for all the songs included. This would serve two purposes, when my show is podcasted the listener would see the song names and not just the show names. Also, we could log the songs played in a automation service so I wouldn't have to type in the songs played again.
Not sure if this is called 'chapters' like Garage Band uses or Label Track in the Audacity manual.
I am not sure what you mean by "meta data". Have you enabled "Show Metadata Editor prior to export step" in
Import / Export Preferences ? Here is the page about Metadata Editor:
http://manual.audacityteam.org/o/man/me ... ditor.html .
Yes I have enabled "Show Meta Data... " and noticed the last imported track's information is stored int he metadata container.
By metadata I am referring to the audio tracks ID3v2 tags stored with the file. Additionally, in Canadian broadcasting we are
Required to log for Canadian Content, some stations also include fem con (an equity term describing female to male ratio involved with the recording), if the song is a hit as describe in the regulations, etc. the additional information is input by trained volunteers for those stations with digital libraries.
Gale Andrews wrote:
If you are importing multiple songs into separate Audacity tracks, then only the metadata (in the sense above) for the last imported song is retained. In any case, if you make all those songs into one Audacity track and export it as one audio file, you can't make separate sections within the one file with metadata for each song.
Yes, this is my understanding. We would appreciate being able to retain the metadata for each track to remain and be displayed at the instant the song is played. Using them as chapters would be a secondary feature we would appreciate.
Gale Andrews wrote:
Have you tried
Splitting a recording into separate tracks - labelling each song, then using File > Export Multiple to export a file for each song? Then you can give each file its own metadata and you can make a playlist comprising the file for each song. This will work fine if you are streaming, but not if you want to give the listeners a single file to download from a web site.
We start with separate track, the songs themselves are distinct. Where things get complex is some programmers with advanced skills will often speak while the track is playing. We can omit logging the spoken word portion unless they mention the radio station, station IDs (StnIDs) which we must do regularly and must log. We can code the meta data for StIDs and they can also be logged.
Gale Andrews wrote:
Again, if you mean metadata like genre and artist name, you will have to type it for each song, because Audacity only retains the metadata for the last file.
Yes, I mean metadata like genre , artist name, title, CanCon and other required information.
