The infra-sound has to be removed before any compression or other processing is applied: unfortunately removing infrasound from the final mix won't correct the fluctuating voice volume :¬(Sam Houston wrote:Trebor - So the workflow would be to add effects, etc then run the "no infrasound" then compress that particular track??
For some reason there is a LOT of infrasound, (sound with frequency lower than 20Hz), on your recording of "shoot her memory down" which can be seen on Audacity's frequency analysis , (click on the image below to see the animation in its entirety) ...
The first thing you should do to a recording of a performance is to remove frequencies below 20Hz with the equalization shown, or similar low-cut / bass-roll-off filter. By doing that you're not removing anything audible, you're getting rid of the low-frequency amplitude wobble which will subsequently interfere with any processing effect which has a threshold setting, e.g. compression, expansion, noise-gate, etc.
