Drum in Live Recording - how to reduce volume
benoits
Post by benoits » Sun Dec 15, 2013 10:06 pm
I made a wonderful live recording of a band where the microphone was placed slightly too close to the drummer. You can hear the guitars, violin, flute and other instruments but the sound of the drum is a little too loud and tends to dominate.
Is there a way, perhaps a tutorial, which could show how to somehow diminish the volume of the drumbeat?
Re: Drum in Live Recording - how to reduce volume
Post by kozikowski » Sun Dec 15, 2013 10:16 pm
It's difficult/almost impossible to split a mixed performance into individual instruments so to make one instrument louder or softer. The people who record a rock concert with nuclear bass notes or neighbor talking on his mobile have the same problem.
You could try Effect > Compressor. That, as a fuzzy rule, knocks down loud sounds to the advantage of softer ones. It also affects the relationship between the other instruments, so it's a juggling act.
Trebor
Post by Trebor » Tue Dec 17, 2013 5:03 am
If the drum beats are louder than everything else, (brief loud peaks poking out of the envelope) they can be reduced to the same amplitude as everything else using a limiter , (which is a compressor with a very fast response time ).
