Working in audacity 2.04 for now, windows 7, but i don't think that affects my question.
I'm recording audiobooks, and I would love to find some simple way to remove or auto-find the sound of my breathing, which ends up really loud and raspy after compression.
i was thinking, is there some threshold i could set to remove anything below it, or a search and replace type feature (hah! but I can dream)?
Anything that can speed up my editing process, since i seem to spend hours taking out breaths, and unfortunately, I cannot simply 'not breathe' - or even move on and off mike, etc. it's just as much work.
Thanx!
--Julie
removing breaths from reading text?
juliehoverson
Re: removing breaths from reading text?
Your dream has been realised: it's called a "noise gate".juliehoverson wrote:... some threshold i could set to remove anything below it ...
You can get one (a plugin) for Audacity here ... http://wiki.audacityteam.org/wiki/Nyqui ... Noise_Gate[/b]
[ That noise gate allows degrees of attenuation up to complete removal of sounds below a threshold.
Complete removal of breaths can make speech sound jarring / staccato ].
If compression is making your breathing louder, then you may need to set the "noise floor" setting of the compressor a bit higher.juliehoverson wrote:the sound of my breathing, which ends up really loud and raspy after compression.
juliehoverson
thanx a bunch! that helps!
