Issue with header info of recorded wav file using Audacity.
santo123
Post by santo123 » Mon Dec 01, 2008 4:17 am
Hi all,
Using a Audacity I have recorded one wav track, but when I read the header of the same track using other program I found the data id as NULL and following chunk size as garbage.
The same program I used for clicktrack generated using Audacity, it gave me proper results.
The program I am using is working fine with other wav files, but I found issues with the recorded tracks using Audacity.
Please help me!
Thanks for you time and help!
Santo.
Re: Issue with header info of recorded wav file using Audaci
Post by steve » Mon Dec 01, 2008 8:46 pm
Audacity does not record WAV tracks. Audacity records Audacity Projects.
To get a WAV file you must Export from Audacity.
http://audacityteam.org/wiki/index.php? ... ement_Tips
santo123
Post by santo123 » Tue Dec 02, 2008 9:09 am
Hi,
Sorry it was my mistake..
Yes I exported the Audacity project to get the WAV output.
Thanks for your reply!
