burro_mail
Post
by burro_mail » Thu Aug 29, 2013 12:37 am
Hi -- I have a vocal recording that
1. is very "dry" (no reverb/echo)
2. The "n" sound sounds like the person's nose is stuffed up
Any suggestions for how to improve the sound?
I am a relative newbie using Audacity 2.0.2 under Mac OS X 10.6.8.
Thank you!
Post
by kozikowski » Thu Aug 29, 2013 1:39 am
You appear to have achieved recording nirvana. Everybody posts about trying to remove room echo from a recording (which you can't do). Adding it is a snap. You can get some depth by making the recording stereo, splitting it and delaying Right with respect to Left. You can also gently add "Effect > Echo" or "Effect > Gverb" to the sound.
That was the good news. We can't fix a broken singer. If they have an adenoid infection or sinus condition, you're kind of stuck with that.
Post some of the performance here. Sometimes your description of the problem is far worse than reality.
http://forum.audacityteam.org/viewtopic ... 49&t=72887
burro_mail
Post
by burro_mail » Thu Aug 29, 2013 3:24 am
Thanks, Koz!
I'll try your tips...
As for posting a sample... um... are you SURE?!
I'll post one, but I encourage you NOT to listen to it!!
The project is simply that I wanted to record some lullabies for my kid, for when she will be away on a trip. So I put the iphone on my chest while I sang to her one night. I AM *NOT* A SINGER, and the the singing is intentionally languid and boring, for the purpose of getting the kid to sleep!
I just thought it would be nice if I could make it a *little* less painful...
- Lullabies_20130822_excerpt1.mp3
- Bad, bad -- painful -- don't listen!
- (836.33 KiB) Downloaded 98 times
Trebor
- Operating System: Windows 8 or 8.1
Post
by Trebor » Thu Aug 29, 2013 6:38 am
burro_mail wrote:The project is simply that I wanted to record some lullabies for my kid, for when she will be away on a trip. So I put the iphone on my chest while I sang to her one night.
(836.33 KiB)
The main problem is it's not loud enough (low signal-to-noise ratio) so there is lots of hiss noise.
If you can re-record try placing the mic of the i-phone closer to your mouth, (and not resting the i-phone directly on your chest : the bassy vibrations of your chest could make it sound muddy / adenoidal ).
External microphones are available for i-phones which may produce better results ...
http://www.amazon.com/s/ref=nb_sb_noss? ... for+iPhone
If you're really keen make a pop-shield ...
https://en.wikipedia.org/wiki/Pop_shield
[ Approximate arrangement : mouth (six-inch-gap) pop-shield (six-inch-gap) microphone ]
If you can't re-record IMO other software does a better job of reducing hiss noise than Audacity ...
burro_mail
Post
by burro_mail » Thu Aug 29, 2013 10:19 pm
Thank you very much!
