Audacity VST compatibility?
Sonic Blaster
Post by Sonic Blaster » Sun Aug 11, 2013 8:44 pm
I am using A. 2.0.3 from the .exe on Vista
I was wondering if this plug-in will work with Audacity- a frequency spectrum analyzer, just another tool in the box...
http://www.voxengo.com/product/span/
thanks
Trebor
Re: Audacity VST compatibility?
Post by Trebor » Sun Aug 11, 2013 11:22 pm
SPAN is a real-time “fast Fourier transform” audio spectrum analyzer plug-in ...
Audacity currently isn't compatible with "real-time" VST effects :cry:
No real-time effects: Audacity cannot yet preview an effect while changing the parameters of the effect. Audacity cannot yet apply effects to audio while it is playing or recording.
VST instrument (VSTi) plug-ins that generate sound are not supported
http://wiki.audacityteam.org/wiki/Plug-ins#Limitations
Sonic Blaster
Post by Sonic Blaster » Tue Aug 13, 2013 9:11 pm
yes thank you
