2.0.3 burned tracks all cut off/burned in different speeds
checkin1
Post by checkin1 » Sun Jul 07, 2013 12:34 pm
Burned 1 long track of music to cd-r, all of them were cut off in the middle, & skipped to the next track.
Used this before, & worked fine, tried all speeds, & still the same, what am I doing wrong?
Re: 2.0.3 burned tracks all cut off/burned in different spee
Post by Gale Andrews » Sun Jul 07, 2013 3:08 pm
If you are using Export Multiple with labels, please click File > Export Labels... and attach the exported label file. Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936 .
If you are exporting one track at a time, make sure you don't use File > Export Selection by mistake.
Otherwise check the burner settings for maximum length of track or similar.
checkin1
Post by checkin1 » Wed Jul 10, 2013 2:46 pm
It is Windows7 Ultimate, version 2.0.3, downloaded I think on exec installer.
checkin1
2.0.3 Tracks cut off/overbuffering or underbuffering?
Post by checkin1 » Wed Jul 10, 2013 2:52 pm
The tracks are cut off all the way through the 80 min track, do I set buffering settings to max or mininmum?
Also, should security be disabled?
Win7 Ultimate, 2.0.3, downloaded exec installation
Re: 2.0.3 Tracks cut off/overbuffering or underbuffering?
Post by steve » Wed Jul 10, 2013 2:55 pm
checkin1 wrote:The tracks are cut off all the way through the 80 min track
Please try to be more descriptive about exactly what is happening / not happening.
Can you give steps to reproduce the problem?
Does this question have anything to do with compiling Audacity from the source code?
Post by Gale Andrews » Fri Jul 12, 2013 11:24 pm
Merged from Compiling Audacity board.
Post by Gale Andrews » Fri Jul 12, 2013 11:27 pm
Please answer the questions and supply the file asked for earlier http://forum.audacityteam.org/viewtopic ... 40#p217240 .
Post by kozikowski » Sat Jul 13, 2013 7:07 am
Music CDs will not carry 80 minutes. It's some number lower and we usually say plan on 78.
Post by Gale Andrews » Sat Jul 13, 2013 11:49 am
If this is the problem you can try http://www.deepburner.com/ - I have had success overburning with that where no other burning program would get it right.
Or just split the tracks across two CD's.
