File length too long?
I have an audio file that is 7 hours 15 minutes long. When I open with Audacity, I only see up to 4 hours. How do I get the entire file to open, even if it's in 2 separate segments??
Re: File length too long?
Where did that file come from?kristaf24 wrote:I have an audio file that is 7 hours 15 minutes long.
What format is the file?
How do you know the file is 7 hours 15 minutes long?
How big is the file (MB)?
Anything else that you can tell us about the file?
How exactly do you open the file in Audacity?kristaf24 wrote:When I open with Audacity, I only see up to 4 hours.
Are there any error messages when you open the file?
Does the 4 hours that opened play correctly?
How to cut into segments.
It's an MP3. I was able to get it to open (the full file) after downloading it again from the server; however, now I can't figure out how to cut it into 2 segments. I've tried searching the forums and online help topics, but no luck. I did the boundary/clip, and it didn't work.
thanks!
thanks!
An easy way to cut into 2 segments:
1) Select the first half of the track, then File menu > Export Selection.
2) Select the second half or the track, then File menu > Export Selection.
