- Quality Assurance
Post
by Gale Andrews » Wed Jun 19, 2013 8:43 pm
[Topic split from
http://forum.audacityteam.org/viewtopic ... 63#p215663]
steve wrote:Gale Andrews wrote:I cheat by entering the length or BPM values in Effect > Change Tempo.
The Quick Calculator is more accurate.
For example, according to "Change Tempo", from 45 to 33.3333 = -26.667 (tempo values are truncated to integers).
Oh yes I remember someone was going on that he wanted fractional BPM support in that effect (length is not truncated).
Should Change Tempo not prevent non-integer BPM input, or better, support fractional BPM?
Gale Andrews on Fri Apr 24, 2015 4:18 pm, edited 3 times in total.
Reason: Topic split and given relevant title
- Site Admin
Post
by steve » Thu Jun 20, 2013 12:40 am
Gale Andrews wrote:Should Change Tempo not prevent non-integer BPM input, or better, support fractional BPM?
I've sent you a patch for fractional BPM support, though note that SoundTouch is not very accurate so allowing fractional BPM does not mean that you will be able to achieve super-accuracy in the stretch length.
- Quality Assurance
Post
by Gale Andrews » Sat Jun 22, 2013 12:27 am
Thanks for the patch. It compiled on Windows, but seemed like the old behaviour, even though I removed the build directory first. I'll have to try it again.
On Ubuntu, it seems fine - a change on a second decimal place BPM affects the outcome length.
How about rounding the displayed length to three decimal places, like BPM?
- Site Admin
Post
by steve » Sun Jun 23, 2013 9:08 pm
Gale Andrews wrote:How about rounding the displayed length to three decimal places, like BPM?
That may be implying greater accuracy than is actually achieved by SoundTouch. When applied to a 30 second audio clip the returned audio is likely to be a few milliseconds out - even hundredths of a second may be a little ambitious.
- Quality Assurance
Post
by Gale Andrews » Mon Jun 24, 2013 2:30 am
It's OK now on Windows.
