http://www.leslieflint.com/recordingsnew.html
The issue is that the original recordings were made in the 50s-70s on reel-to-reel and occasionally a cassette recorder. If you listen to a few, you will note they suffer from nearly inaudible to pretty damn good considering the time, place and conditions (dark seance). My mission is to take the .swf files, to clean them up, and to convert them to files which can be used to perform transcriptions. Transcriptions = my poor typing skills, headphones and a step pedal to forward and reverse the files.
I believe but don't know if it is true that the files will have to be inmp3 form to be able to fwd-rev them. Obviously, this means that their may be a downgrade in quality of the files and this is defeating the purpose. As you can see, I am lost and clueless at the same time.
All suggestions welcomed.
P.S. The .swf files are go-pause-stop only (i.e. they cannot be advanced in increments) unless, again, I am missing something.
