FFmpeg not found.
smooth_pierre
FFmpeg not found.
Just got the ffmpeg not found message, only just happened between exporting multiples, so I promptly downloaded the necessary file for the library, BUT, Audacity cant see it or pick it up on my laptop. I have downloaded it three times now all to no avail, even reinstalled Audacity - I am not a total 'newbie' but I cant see why this is happening. Help and advice please.
Re: FFmpeg not found.
Ensure that you precisely follow the instructions here: http://manual.audacityteam.org/o/man/fa ... tml#ffdown
smooth_pierre
Followed the procedure precisely and still 'no go' dont know where now, download as MP3 and convert with alternative software I suppose.??
Which exact version of Audacity are you using? (look in "Help > About Audacity" for the version number).
What exactly happens (step-by-step) when you go through the steps to Locate the FFmpeg library manually ?
If all else fails you could export as WAV format and then convert the WAV file with a third party encoder.
No, best not to do that as that will then be doing two "lossy compression" steps which will adversely affect the sound quality.smooth_pierre wrote:download as MP3 and convert with alternative software I suppose.??
