Blending Two or more tracks up and down
mcgervase
Post by mcgervase » Tue Nov 04, 2008 5:52 am
I have a voice over track and I want a background sound track to go up and down in volume in the appropriate spots. How can I do this smoothly like I had used a slider control?
thanks
Mark
waxcylinder
Re: Blending Two or more tracks up and down
Post by waxcylinder » Tue Nov 04, 2008 11:34 am
You can use the Envelope tool to vary the volume of your backing track. The envelope tool is accessed by the tool button with the icon that looks like a white dot with two triangles pointing at it and a blue-line going through it.
When you activate the envelope tool you will see blue lines added to your track - you can drag these around to change the volume.
