What does it mean exactly:
It seems to be very important info to me but do not understand, sorry.Gale Andrews wrote:Quite likely, but one of the test files is 5:1 so that won't be suitable for audio CD.
Thanks,
Attila
What exactly is that input?equinox wrote:I have to use a PC connected to the PC-input of the player
It means one of the test files you linked to on http://www.linnrecords.com/linn-downloa ... files.aspx is "24bit 88.2kHz 5.1 Surround Free Lossless Audio Codec*. It means there are six channels in the file (four more than usual left and right for stereo).equinox wrote:What does it mean exactly:
Yes it has a coaxial and optical digital in - see here http://www.marantz.co.uk/uk/Products/Pa ... IPearlLite from where you can also download the manual (which I've looked at).steve wrote:What exactly is that input?equinox wrote:I have to use a PC connected to the PC-input of the player
Does the Marantz have "digital in"? If so, what format does that support?
