i really need help with this
defstar
Post by defstar » Tue Oct 21, 2008 6:07 pm
ok, so this has been asked loads of times but i really need help with this. i'm doing a series of voices for a halloween party and i need help doing Dalek, Cyberman and Davros voices... can someone please help me with this
Re: i really need help with this
Post by steve » Wed Oct 22, 2008 4:07 pm
For a Dalek, use a "ring modulator" against a frequency of about 30 Hz (LADSPA plug-in "Ringmod wih LFO"), then add a bit of "Chorus" effect.
Sorry, I can't remember what Cybermen sound like.
MlleBienvenu
Post by MlleBienvenu » Sat Oct 25, 2008 9:31 am
These are the settings I use... you probably won't need the pitch change in the beginning, I'm female so I add that to sound a bit more male.
Cybermen Voice:
Pitch: -40
Delay:
-----Decay amount: 10
-----Delay Time: .01
-----Number of Echoes: 30
Copy-Paste
timeshift 2nd sample slightly
Quick Mix
Copy-Paste
Pitch: -35
Dalek:
Pitch: -15
Killeringer:
-----Root Pitch: .003
-----Speed: .01
-----Amount: .01
Cybermen other:
Killeringer:
-----Root Pitch: .033
-----Speed: 0
-----Amount: 0
Luigiman
Post by Luigiman » Thu Jul 07, 2011 2:11 am
MlleBienvenu wrote:These are the settings I use... you probably won't need the pitch change in the beginning, I'm female so I add that to sound a bit more male.
Cybermen Voice:
Pitch: -40
Delay:
Copy-Paste
Quick Mix
Copy-Paste
Pitch: -35
Dalek:
Pitch: -15
Killeringer:
-----Speed: .01
-----Amount: .01
Cybermen other:
Killeringer:
-----Speed: 0
-----Amount: 0
How exactly did you get the killerringer to have the specified root pitch? Mine only goes down to 22.
