remove the singing from this clip
megabuff
Post by megabuff » Sat Jul 14, 2012 8:53 am
Hi there
I tried to remove the singing from this clip by following the instructions on this site, however the singing was still there, although a bit quieter, but the track had a strange ehco type sound to it as well, so not a great result.
i was wondering if there were any gurus who may have some advice.
I have uploaded the original unedited copy here, if anyone is interested......
http://picosong.com/wgDC
thanks for reading :-)
Trebor
Re: remove the singing from this clip
Post by Trebor » Sun Jul 15, 2012 12:53 am
megabuff wrote:I tried to remove the singing from this clip by following the instructions on this site, however the singing was still there, although a bit quieter, but the track had a strange ehco type sound to it as well, so not a great result.
The "invert one track" method doesn't work when there is stereo echo/reverb on the centre-panned vocal : the stereo reverb means the vocal is no longer identical in both left and right channels so the destructive interference technique doesn't work and some echoey vocal remains.
like it says in the manual the vocal remover only works on some stereo tracks ... http://manual.audacityteam.org/help/man ... ation.html
megabuff
Post by megabuff » Mon Jul 16, 2012 10:11 am
they there, thanks for your reply
so in this case there is no way to remove the vocals?
Trebor
Post by Trebor » Mon Jul 16, 2012 10:33 am
megabuff wrote:so in this case there is no way to remove the vocals?
No, I don't think it's possible on that track, even using other techniques.
megabuff
Post by megabuff » Mon Jul 16, 2012 10:43 am
oh well, thanks anyway!
do you think any other program on the market would be able to do it?
Trebor
Post by Trebor » Mon Jul 16, 2012 11:38 am
megabuff wrote:do you think any other program on the market would be able to do it?
I don't think anything could do it: the piano and voice are similar in frequency-content and their position in the stereo field, they would have to differ in some respect to be able to separate them.
Extraboy pro is designed to extract sounds from a mix, but like I said I don't think vocal removal is possible on the Joe Jackson track.
megabuff
Post by megabuff » Tue Jul 17, 2012 8:37 am
ok thanks for yous reply i appreciate your help
