hi
i used soundsoap by bias and now they went belly up so i need a software to cleanup 78sbesides audacity what other software can you recommend to me?
lenny
an alternet software besides audacity
coonsanders
Re: an alternet software besides audacity
Waxcylinder is rather keen on Brian Davies restoration software ... http://forum.audacityteam.org/viewtopic.php?f=28&t=1994
I've not tried the Brian Davies software but I have tried Goldwave whose noise reduction is better than Audacity IMO.
I believe both Brian Davies and Goldwave have free trials, so you can try before you buy.
[ You may still be able to use soundsoap if you have the authorization code ... http://www.bias-inc.com/ ]
coonsanders
hi i have brian davies click repaire and goldwave too..davies noise reduction id pretty complicated..thanks anyway
lenny
lenny
Waxcylinder has posted his settings for Brian Davies software ... http://forum.audacityteam.org/viewtopic ... 1994#p8400coonsanders wrote:..davies noise reduction id pretty complicated..
