allow playback start close to playback cursor
I've only been working with Audacity for a few hours and I find it to be AWESOME!
That said, I do have a question/suggestion.
In the Windows version when one left-clicks on the timeline, playback starts at the pointer location and a green playback cursor is established. A gray quick-play-range is established just below the green playback cursor. If one wishes to jump to a significantly earlier or later place on the timeline, it's easy to do...just left-click where you wish to jump to and playback starts where you click. However, if you wish to jump a short distance, you can't. The existence of the gray quick-play-range prevents you from clicking close to the green playback cursor.
I'm taking radio shows and deleting the commercials. I find the commercials by clicking along the timeline. When I find the commercial, I then want to find the beginning, label the beginning, find the end, label the end, then highlight/delete the commercial. The problem is that when I've clicked close to the beginning of the commercial, I can't re-click to zero in on the exact beginning because the gray quick-play-range prevents me from doing so.
If the gray quick-play-range device didn't affect the pointer when the pointer is up by the green playback cursor, that would solve this problem.
Re: allow playback start close to playback cursor
It may be because I'm on Linux that I can't reproduce this problem, or it may be that you have "snap to" selected in the "Selection Toolbar".
I don't have "snap to" selected, so maybe it happens in the windows version and not linux....
Where do we go from here?
Thanks
Thanks
Ah, sorry, I misread your post, I was clicking on the track, not the timeline.
This is the way I would edit out an advert (in Audacity 1.3.5):
1) Select the region of the commercial (roughly)
2) Press the space-bar to start the playing.
3) if I need to adjust the start position, press the space-bar to stop, then drag the selected region by using "Shift + Mouse" on the track.
Adjusting the end position of the selection is a bit more tricky, but the improved "labels" in Audacity 1.3.x can help.
1) Set a label (Ctrl+B) to the selected region.
2) Draw a new selection near the end of the label (the cursor will turn yellow when it lines up with the label position)
3) Test the end position, and if necessary adjust the end marker of the label.
Note that clicking on the label name (even if it is an empty name) will select the label region, but it will also move keyboard focus to the label track. Focus can be restored to the audio track by using the up/down cursor keys.
Thanks for your reply Stevethefiddle.
I've had pretty good success removing commercials using 1.3.5. I am trying to improve on my current process.
I'm editing out 15 or more groups of commercials spread throughout a 2.75hour program.
My process is this:
1- I open the mp3 file in Audacity.
2- I click close to the start of the timeline which begins playback.
3- If I don't hear a commercial, I click on the timeline again...a little further to the right...till I find a commercial.
4- When I find a commercial, I find its beginning, then hit control-m, establishing a "start" label (example = 1s).
5- I click on the timeline restarting playback till find the end of the commercial, control-m to establish an "end" label (1e)
6- Repeat throughout the entire file establishing start and end labels (2s, 2e...15s, 15e...etc.) for each commercial
7- Once all the commercials beginnings & endings are labeled, I start deleting them.
8- I start from the END of the file and work toward the beginning. I click within the track close to an end-label. If I'm close enough, the highlighting will snap to the end-label and a yellow line will show up. I then drag toward the left till I'm over the start-label at which time another yellow line will appear. I release the mouse button and hit the delete key. I've just deleted the last commercial.
9- I eleminate the last start and end-labels, then repeat step 8 with the next to the last commercial.
My problem is when I try to find the exact beginning or ending of a commercial. When I click on the timeline and find that the playback position is several seconds past the beginning of the commercial, I can't just click a few seconds earlier. The pointer changes from a finger to a double-headed-arrow which won't allow me to restart playback at a few seconds earlier. I've gotten around this a little by switching to keyboard left/right keys. That's been more efficient.
Perhaps the best solution would be to make the green playback indicator dragable?!?
Again, thanks for your reply,
miker
My process is this:
miker
There is a way round this - you need to be at an appropriate zoom level for this to work.miker wrote:My problem is when I try to find the exact beginning or ending of a commercial. When I click on the timeline and find that the playback position is several seconds past the beginning of the commercial, I can't just click a few seconds earlier.
Lets look at your example with some numbers put in:
- 1) There was an advert that starts at exactly 1 hour (1:0:00)
2) The advert is exactly 1 minute long
3) You have dropped markers at 1 hour and 10 seconds (1:0:10) and 1 hour, 1 minute and 12 seconds (1:1:12)
4) You click on the time-line, at say, 1:0:01 and playback begins at 1:0:01
5) You realise that you started playback just a little too late
6) You now have a problem because you can't click on the time-line at 1:0:00 (because the pointer changes from a finger to a double-headed-arrow)
You first want to find the point at which the program stops and the commercial begins:
Steps 1,2 and 3 as above;
- 4) Zoom in or out so that you can see about 20 seconds to the left and the right of your "start marker" (You can now see from 0:59:50 to 1:0:30)
5) Select the area between the two markers by dragging the mouse over the track with the left button pressed.
6) Press Shift + Space-bar to begin looped playback
7) You realise that you have started playback too late, so now you either:
7a) Click on the track at a point before the programs stops (say 0:59:55) and drag to the Right to where you think the program finished (just before the commercial starts). Let's say that you drag from 0:59:55 to 1:0:01 - Play is now looping around the last few seconds of the program, and the first 1 second of the commercial.
8a) You realise that 1:0:01 is just a little too late, so you now drag from 0:59:55 to 1:0:00. Success
or
7b) Click on the track at a point a few seconds after the commercial has started (say 1:00:25) and drag to the Left to where you think the advert started and the program finished - lets say you drag from 1:00:25 to 1:0:01 - Play now loops the first part of the advert, starting 1 second after the beginning.
8b) You realise that 1:0:01 is just a little too late, so you now drag from 1:00:25 to 1:0:00. Success
Stevethefiddle, you've been very helpful.
I've played around with labels a bit differently based on your suggestions/encouragement.
I now see that if I use a label as an area, rather than as a point, that I get some of what I need.
What's funny to me is that establishing a label via control-m doesn't create an area...it creats a point.
Now that I see a label as an area, and that when I click in the text area of an area label, it DOES highlight the audio track...and I can move the label start/end points and see via the highlighting where the label area hits the audio track.
Very helpful.
Thanks again for your help,
miker
Very helpful.
miker
waxcylinder
Mike,miker wrote:What's funny to me is that establishing a label via control-m doesn't create an area...it creats a point.
that's because CTRL + M is designed to create a Marker position as you record or playback
CTRL + B is designed as the shortcut for creating labels - either as a point label, or as a labelled section if you have some audio selected at the time.
Very interesting. Your info brings me back to when I started my search in this arena. I searched the web looking for the capabilities I knew as "Mark-In" and "Mark-Out". My search results included comments within the Audacity Forum that lead me to the Audacity concept of Labels (as well as leading me to Audacity itself!) WC, I'd love it if the Audacity folks turned control-m into markers! If I could be listening to a file, hit a key-combo to "mark-in" the start of a commercial, skip forward to where I suspected the end of a commercial is, hit another key-combo to "mark-out" the end of the commercial, then after the commercials were all identified with their own mark-ins/mark-outs, hit the delete key to remove all the commercials, that'd be a beautiful thing.waxcylinder wrote:Mike,miker wrote:What's funny to me is that establishing a label via control-m doesn't create an area...it creats a point.
Working with the labels has been pretty close to that, though. I'm definitely NOT complaining. I'm VERY MUCH enjoying working with 1.3.5 (and look forward to 1.4!)
I do still think the playback functionallity isn't exactly what the programmers intended. I'd think they'd want to initiate playback when clicking on the timeline at any location. Hence my original statement of this string.
Thanks WC,
miker
- Quality Assurance
I think I'd agree. When you click in the timeline and then drag the cursor, you cannot do anything with that region because it disappears when you stop play. Creating the quick-play region should always be just by click and drag, with no cursor visible until you drag. I've added it to our Wiki Feature Requests page along with other Quick Play suggestions:miker wrote:I do still think the playback functionallity isn't exactly what the programmers intended. I'd think they'd want to initiate playback when clicking on the timeline at any location.
http://audacityteam.org/wiki/index.php? ... hancements
I wouldn't use Quick Play for what you are doing, rather click in the waveform and use the arrow keys as you suggest. To change playback position, click and double spacebar, or click with CTRL depressed.
You were also asking about labels showing their point or region in the waveform when you move them. I think WC deleted that post because it was a Feature Request post here. We delete those after a month when they are considered for addition to our Wiki Feature Requests page. I don't think we would want to do this, so I won't be adding it as a Feature Request. The reason is that it would destroy an existing cursor point or selection region which you might want to keep. But if you do want to see the point or region referred to by the label appear in the waveform, all you need to do is click in the label.
