Removing certian noises
95GTSpeedDemon
Post by 95GTSpeedDemon » Thu Mar 22, 2012 8:21 pm
I made a trip to a drag strip recently and a friend took video from the starting line. while going down the track, the next car inline started his burn out, which over powered everything.
my car, getting close to 1/4mi away is not very loud to the camera, but with no other noises, it would be audible.
Is it possible to remove the other persons engine/tire noise, while keeping the rest?
I
Re: Removing certian noises
Post by steve » Thu Mar 22, 2012 8:50 pm
Short answer, no.
If you want a longer answer please ask ;)
95GTSpeedDemon
Post by 95GTSpeedDemon » Thu Mar 22, 2012 8:52 pm
thank you. i was figuring that was the case.
is there software that is able to do things like this?
Post by steve » Fri Mar 23, 2012 1:51 am
Only in films and TV.
95GTSpeedDemon
Post by 95GTSpeedDemon » Fri Mar 23, 2012 3:36 am
ok, thank you for your help!
Post by steve » Fri Mar 23, 2012 1:14 pm
Have you seen in spy films where the hero goes into the bathroom and turns on the shower when his room is bugged so that the baddies can't hear what he's saying? That part is quite realistic. The shower makes "broadband noise" (wide range of frequencies) that masks his voice. If the broadband noise is as loud or louder than the sound that it is masking it is not possible to remove the noise without also removing or severely distorting the other sound.
Very low level constant noise can be removed quite effectively with the Noise Removal effect. The lower the noise level, the better the effect works. With loud noise it does not work.
