Progressive amplification
mascino
Post by mascino » Mon Jan 23, 2012 2:34 pm
Is there a way (or a plugin) to amplify a sound progressively: I mean a sort of fade in ora fade out which starts or stops at a certain amount of volume...
Re: Progressive amplification
Post by kozikowski » Mon Jan 23, 2012 3:28 pm
You can drag-select and apply Effect > Fade In or Effect > Fade Out.
You can also use the Envelope tool (two white arrows and bent blue line) to create a custom fade and there you can define both ends.
http://kozco.com/tech/audacity/pix/CrossFade.jpg
Those blue lines are rubber bands and you can push them around to do whatever you want.
mascino
Post by mascino » Mon Jan 23, 2012 3:44 pm
Maybe I don't explain well what I meant.
The "Fade in" effect increases the volume from silence to "X".
I have a track with "x" volume and I want to amplify it progressively (not instantly, so I can't use the "amplify" effect) from "x" to "x+7"...
waxcylinder
Post by waxcylinder » Mon Jan 23, 2012 6:10 pm
As Koz suggested: use the envelope tool - see: http://manual.audacityteam.org/man/Envelope_Tool
Post by steve » Mon Jan 23, 2012 7:28 pm
There is also this Nyquist plug-in that seems to match your description: http://forum.audacityteam.org/viewtopic ... 42&t=40900
See here for how to install plug-ins: http://audacityteam.org/download/plugins
mascino
Post by mascino » Tue Jan 24, 2012 10:51 am
Fade by db seems perfect! Thanks!
