There is usually a constant "Noise floor”, ( * see quantization noise and dither noise)Soldado266 wrote:Trebor, why did you say that the signal to noise ratio is lower? When we decrease the signal amplitude by using compressor/amplify/envelope tool I thought the noise was also decreased , thus keeping the ration constant. No?
I’d just like to concur with bgravato and Steve: I too can’t hear any obvious hiss in the “low level” recording (before I amplified it).
* you could try "exporting" (saving) your Audacity files in 32-bit depth WAV format to avoid this constant but minute noise, if you've got plenty memory.
http://wiki.audacityteam.org/wiki/DitherDither [noise] is only applied when converting from a higher bit depth to a lower bit depth. Exporting to WAV or other uncompressed audio format is virtually lossless in all situations. However there may be a very small amount of change to the audio data with some types of uncompressed audio export, depending on the settings in Audacity Preferences (see below).
Exporting to 32-bit PCM WAV format is 100% lossless - no dithering is applied.
Exporting to 24-bit PCM WAV format may be dithered with a peak dither level of around -130 dB
Exporting to 16-bit PCM WAV format may be dithered with a peak dither level of around -80 dB
