Converting long multi-track file into many single-track fyls
kds-kds
Post by kds-kds » Tue Mar 29, 2011 6:39 am
Hello,
I've been trying to find simple freeware along the lines of UnRarX in which you can open (or drop) a single long audio-file (aiff, wav, mp3) comprising many tracks and the app spits out individual mp3s, each comprising a single track. Couldn't find any free app that does this. Neither iTunes nor Audacity have this feature though you can do so manually in the latter. Wouldn't it be simple enough within the Audacity code-base to add this feature by finding all inter-track pauses (it could try to find them itself, prompt the user for them, and/or have a field in some part of the Preferences) and export, in a single step, all at once, the whole file into many individual-track mp3 (or other format) files? Or is this already doable? FYI I'm still on an ancient version 1.2.6 because (a) it suffices for my limited needs and (b) I'm still on 10.4.11(!)
Thanks,
KDS
waxcylinder
Re: Converting long multi-track file into many single-track
Post by waxcylinder » Tue Mar 29, 2011 10:53 am
Audacity already has silence finder and sound finder functions - see down the page in this entry from the Audacity 1.3 manual: http://manual.audacityteam.org/man/Analyze_Menu
You will need to use 1.3 for this as I don't believe that 1.2 had these features. And note that it doesn't always work as you expect as the gaps between tracks on an LP or tape are rarely "silent" - which is why you have to play with the thresholds. And for classical music in particular false silences can be detected which are not inter-track gaps.
kds-kds
Post by kds-kds » Wed Mar 30, 2011 9:57 am
Hello,
First a couple of minor points.
The referred-to page makes mention of Silence Finder and even shows its dialogue window but it doesn't say *how* to get there (i.e. through which top-level menu). I found the answer (Analyze) in the tutorial page. This should be mentioned in the other page too.
Next, doing an Export Multiple after doing Silence Finding sometimes results in the first and/or last track not being exported because it 'thinks' a track is bracketed by silence but a multi-track file may not begin and end with anything more than a millisecond of silence. IMHO, it would be smarter for Export Multiple to also export from start of file to first silence and from last silence to EOF. (I can guess the workaround: simply add a couple of seconds of silence to the start and end of file before using Silence Finder, just to make sure.)
Actually, these features *are* available in good old 1.2.6 so 'my bad' that I did not know about it or find it.
Finally, waxcylinder you da man! Thank you! And Audacity *rocks*! (It also rolls.)
KDS
waxcylinder
Post by waxcylinder » Wed Mar 30, 2011 10:21 am
kds-kds wrote: ... The referred-to page makes mention of Silence Finder and even shows its dialogue window but it doesn't say *how* to get there ...
kds, the page I pointed you out has the header "Analyze Menu" and as such it is implicitly trying to say that all the analysis tools are available from the Audacity "Analyze" menu. The documenters assumed that was clear enough - but are you saying that that is not the case and could be made clearer and more obvious for the reader?
Thanks for pointing this out.
waxcylinder
Post by waxcylinder » Wed Mar 30, 2011 10:29 am
kds-kds wrote: ... doing an Export Multiple after doing Silence Finding sometimes results in the first and/or last track not being exported because it 'thinks' a track is bracketed by silence but a multi-track file may not begin and end with anything more than a millisecond of silence. IMHO, it would be smarter for Export Multiple to also export from start of file to first silence and from last silence to EOF. (I can guess the workaround: simply add a couple of seconds of silence to the start and end of file before using Silence Finder, just to make sure.)
Note to fellow forum elves: do we think that this is really a feature request or should it more properly be reported as a bug?
bgravato
Operating System: Linux Debian
Post by bgravato » Wed Mar 30, 2011 11:22 am
Regarding the file splitting I can say that I've been successfully using mp3splt on linux: http://mp3splt.sourceforge.net/mp3splt_page/home.php
It's available for mac too through fink and macports (and there's also a windows installer on the download page). I've only tested it in linux though (and the command line tool only, I haven't tried the GUI yet).
It has the advantage that it can split mp3 files without decoding/reencoding them.
I hope this helps.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Post by steve » Wed Mar 30, 2011 4:55 pm
kds-kds wrote:The referred-to page makes mention of Silence Finder and even shows its dialogue window but it doesn't say *how* to get there (i.e. through which top-level menu). I found the answer (Analyze) in the tutorial page. This should be mentioned in the other page too.
You mean on this page: http://manual.audacityteam.org/man/Analyze_Menu
Did you miss the big bold title at the top where it says "Analyze Menu"?
kds-kds wrote: IMHO, it would be smarter for Export Multiple to also export from start of file to first silence and from last silence to EOF.
If you use "Analyze menu > Sound Finder" (available in Audacity 1.3.x only), the first section will be marked even if there is no silence at the beginning.
If you use "Silence Finder" then you may need to use the option in the Export Multiple dialogue to "include audio before first label" (available in Audacity 1.2 and 1.3)
Silence Finder and Sound Finder operate on single audio tracks.
For multi-track projects, if you want to split the project, taking into account all of the tracks, you should mix the tracks down before using either Silence Finder or Sound Finder. In Audacity 1.2, to mix the tracks use "Project menu > Quick Mix". In Audacity 1.3, to mix the tracks use "Tracks menu > Mix and Render".
If you need to keep the project as separate tracks, but you want to create labels based on the full mix, in Audacity 1.3 you can use:
Ctrl+A (select All tracks)
Ctrl+Shift+M (Mix to new track).
Then apply Silence Finder or Sound Finder to the new (mix) track.
Then delete the Mix track.
kds-kds
Post by kds-kds » Wed Mar 30, 2011 6:10 pm
kds, the page I pointed you out has the header "Analyze Menu" . . . could be made clearer and more obvious for the reader?
First, I goofed; that said, perhaps yes. If someone is wanting to learn Audacity, he/she won't miss that header on the top of the page but if someone wants to dive in (land on the page and do a find) to get the one solution he needs, he'll miss it. I see no harm and only an advantage if the heading of the page, corresponding to a top-level menu choice, is in a larger font and colourized boldface.
bgravato, thanks but my need is to split a multi-song source of any one of a few different audio formats, not just mp3.
Yes! :(
then you may need to use the option in the Export Multiple dialogue to "include audio before first label" (available in Audacity 1.2 and 1.3) . . .
I saw that but it was greyed out. Confirmed that it doesn't work in my version. (Selected audio to ensure that there would be audio before the first silence point, did the Silence Find, and went to Export Multiple, in the dialogue the 'Label' radio button is on, but the 'include audio before first . . .' checkbox remains greyed out -- disabled.)
We're using the word 'track' in different senses and, because this is a technical forum, I probably shouldn't have used it in that sense. My sense: "This CD has 20 tracks!" Yours: "The rhythm track lacks immediacy and the vocal track's off-centre." Trust this clears up the confusion.
As two Audacity persons are looking at this post, what do you think of Audacity being able to capture multiple inputs (on-board mic, line-in, USB input, and on-board app input a ala Audio Hijack). I realize it was conceived as some kind of audio mixing/production app but now that it's become an everything and the kitchen sink audio app, why not?
Thanks to everyone,
KDS
Post by steve » Wed Mar 30, 2011 7:29 pm
kds-kds wrote:(Selected audio to ensure that there would be audio before the first silence point, did the Silence Find, and went to Export Multiple, in the dialogue the 'Label' radio button is on, but the 'include audio before first . . .' checkbox remains greyed out -- disabled.)
I can't reproduce that.
Are you using Audacity 1.3.12?
Could you give me a step-by-step method so that I can reproduce the issue. (If screen-shots will help, there is a screen-shot tool in the Audacity Help menu. Up to 3 images can be uploaded in a forum post using the "Upload Attachment" tab below the compose message box).
kds-kds
Post by kds-kds » Thu Mar 31, 2011 6:14 am
steve wrote: Are you using Audacity 1.3.12?
No, as I'd written in my original post, "FYI I'm still on an ancient version 1.2.6 because (a) it suffices for my limited needs and (b) I'm still on 10.4.11(!)" So the reason you couldn't reproduce the bug is that we're probably using different versions.
I also noticed on the main Audacity page (http://audacityteam.org/) that 1.3.12 is called the 'beta' and 'work in progress' while 1.2.6 is called 'main' and 'complete'; however, you get a download choice between one or the other and not a stable 1.3.x release (i.e. an in-between release, say 1.3.8, may have been a good stable release)
Also, reading that page I realize that 1.2.6 is not 'ancient' as I had thought it to be!
