Equalizer Graphics
Equalizer Graphics
Post by kozikowski » Mon Jun 09, 2008 8:13 pm
I have transferred this FR and its vote to the Wiki today 14Jul08 - but retained this thread in the Forum, but relocated to Audio Processing - WC
This one should be pretty harmless.
I want pinstripes inside the equalizer work window to tell me where I am. Quick, point to a place 4 dB down at 7500 Hz.
No, I can't do it, either, although I need to do it because that's part of a complex curve I want to build. A much harder version of this involves two windows that read out the cursor position, similar to what happens in the analyzer. That would be a programming pain in the butt.
Either one would be welcome.
Reason: FR moved to Wiki - this thread relocated to Audio Processing
Re: Equalizer Graphics
Post by steve » Mon Jun 09, 2008 9:17 pm
Check out the file "EQCurves.xml"
I'm not sure where it will be on a Mac, but in Linux it's: home/<user>/.audacity-data/EQCurves.xml
They can be as simple or complex as you like. They can be edited directly and they are probably transportable.
Try copy and pasting these curve into your "EQCurves.xml" file:
Code: Select all
	<curve name="ska">
		<point f="20.00" d="-15.0"/>
		<point f="25.00" d="-2.9"/>
		<point f="30.00" d="2.6"/>
		<point f="40.00" d="4.8"/>
		<point f="50.00" d="5.0"/>
		<point f="60.00" d="5.0"/>
		<point f="80.00" d="3.0"/>
		<point f="100.0" d="0.8"/>
		<point f="120.0" d="-0.9"/>
		<point f="150.0" d="-2.5"/>
		<point f="200.0" d="-5.0"/>
		<point f="300" d="-8.4"/>
		<point f="400" d="-10.0"/>
		<point f="600" d="-8.0"/>
		<point f="1200" d="-2.0"/>
		<point f="1300" d="1.05"/>
		<point f="1400" d="-2.0"/>
		<point f="1500" d="-4.0"/>
		<point f="1600" d="-4.0"/>
		<point f="2000" d="-8.0"/>
		<point f="3000" d="-2.5"/>
		<point f="4000" d="2.0"/>
		<point f="6000" d="4.0"/>
		<point f="10000" d="4.0"/>
		<point f="18000" d="0.8"/>
		<point f="24000" d="0.0"/>
	</curve>
or a simple one
Code: Select all
	<curve name="slope">
		<point f="20" d="-15"/>
		<point f="800" d="-10"/>
		<point f="2000" d="-5"/>
		<point f="10000" d="0"/>
		<point f="24000" d="5"/>
	</curve>
or a high precision one
Code: Select all
<curve name="stevethefiddle">
		<point f="20.000000000000" d="-15.250000000000"/>
		<point f="20.808085587751" d="-14.828845528587"/>
		<point f="21.648821291359" d="-13.210369678949"/>
		<point f="22.523526315227" d="-10.421537752467"/>
		<point f="23.433573165260" d="-7.506270226987"/>
		<point f="24.380389802479" d="-5.000612646688"/>
		<point f="25.365461883636" d="-2.878729210669"/>
		<point f="26.390335092377" d="-1.143066633971"/>
		<point f="27.456617564581" d="0.151825562244"/>
		<point f="28.565982411698" d="1.077789612328"/>
		<point f="29.720170346040" d="1.881386973913"/>
		<point f="30.920992412148" d="2.583268093849"/>
		<point f="32.170332828509" d="3.102141977255"/>
		<point f="33.470151944103" d="3.542030752102"/>
		<point f="34.822489314397" d="3.909475294480"/>
		<point f="36.229466901626" d="4.210700032747"/>
		<point f="37.693292404382" d="4.462668429028"/>
		<point f="39.216262721726" d="4.666340670329"/>
		<point f="40.800767557271" d="4.830937750120"/>
		<point f="42.449293168882" d="4.945400395213"/>
		<point f="44.164426269882" d="4.996846125663"/>
		<point f="45.948858087882" d="5.000000000000"/>
		<point f="47.805388587604" d="5.000000000000"/>
		<point f="49.736930864329" d="5.000000000000"/>
		<point f="51.746515714852" d="5.000000000000"/>
		<point f="53.837296393127" d="5.000000000000"/>
		<point f="56.012553558067" d="5.000000000000"/>
		<point f="58.275700421238" d="4.973853617362"/>
		<point f="60.630288102564" d="4.889769745216"/>
		<point f="63.080011202408" d="4.747852733618"/>
		<point f="65.628713598801" d="4.555235043702"/>
		<point f="68.280394478894" d="4.308322783647"/>
		<point f="71.039214614112" d="4.007122899922"/>
		<point f="73.909502888854" d="3.678153390726"/>
		<point f="76.895763092971" d="3.346263433819"/>
		<point f="80.002680988700" d="3.011432950309"/>
		<point f="83.235131663122" d="2.649756226695"/>
		<point f="86.598187177699" d="2.284732287898"/>
		<point f="90.097124526884" d="1.916517687132"/>
		<point f="93.737433918284" d="1.551122496975"/>
		<point f="97.524827387392" d="1.191623919953"/>
		<point f="101.465247760377" d="0.838021956066"/>
		<point f="105.564877979016" d="0.490316605314"/>
		<point f="109.830150802394" d="0.148507867696"/>
		<point f="114.267758900593" d="-0.188892244184"/>
		<point f="118.884665356203" d="-0.529225458909"/>
		<point f="123.688114590153" d="-0.873484348831"/>
		<point f="128.685643728974" d="-1.196999455758"/>
		<point f="133.885094431369" d="-1.514860930285"/>
		<point f="139.294625192605" d="-1.835930013061"/>
		<point f="144.922724146073" d="-2.160310658875"/>
		<point f="150.778222382078" d="-2.488404350321"/>
		<point f="156.870307804764" d="-2.820250990771"/>
		<point f="163.208539548921" d="-3.173835531941"/>
		<point f="169.802862979293" d="-3.549697551976"/>
		<point f="176.663625295917" d="-3.930152669947"/>
		<point f="183.801591769993" d="-4.309858134833"/>
		<point f="191.227962635747" d="-4.672483920902"/>
		<point f="198.954390664797" d="-5.016894619758"/>
		<point f="206.992999450601" d="-5.343090231399"/>
		<point f="215.356402431673" d="-5.651070755826"/>
		<point f="224.057722683423" d="-5.940891062086"/>
		<point f="233.110613509667" d="-6.235809959491"/>
		<point f="242.529279866118" d="-6.554935638023"/>
		<point f="252.328500649494" d="-6.895400605699"/>
		<point f="262.523651887182" d="-7.249676472032"/>
		<point f="273.130730863876" d="-7.626518712358"/>
		<point f="284.166381223030" d="-8.022872881405"/>
		<point f="295.647919082519" d="-8.395097889039"/>
		<point f="307.593360205482" d="-8.728971249350"/>
		<point f="320.021448268984" d="-9.020896172488"/>
		<point f="332.951684274858" d="-9.270777421888"/>
		<point f="346.404357148860" d="-9.484764404471"/>
		<point f="360.400575576173" d="-9.663127261308"/>
		<point f="374.962301123193" d="-9.808568867676"/>
		<point f="390.112382697579" d="-9.921786244100"/>
		<point f="405.874592400641" d="-10.004453978460"/>
		<point f="422.273662828311" d="-10.054551206102"/>
		<point f="439.335325879237" d="-10.067715250055"/>
		<point f="457.086353130889" d="-10.045360478063"/>
		<point f="475.554597847034" d="-9.994443174966"/>
		<point f="494.769038682487" d="-9.915900374063"/>
		<point f="514.759825153732" d="-9.812761512598"/>
		<point f="535.558324946738" d="-9.684715855885"/>
		<point f="557.197173136223" d="-9.530916782724"/>
		<point f="579.710323393581" d="-9.350155918295"/>
		<point f="603.133101263832" d="-9.140082362104"/>
		<point f="627.502259595185" d="-8.900635564251"/>
		<point f="652.856036208198" d="-8.640110081676"/>
		<point f="679.234213895013" d="-8.352923686697"/>
		<point f="706.678182842822" d="-8.038246139522"/>
		<point f="735.231005579501" d="-7.706821634408"/>
		<point f="764.937484543336" d="-7.375212513928"/>
		<point f="795.844232382847" d="-7.043603393448"/>
		<point f="827.999745097028" d="-6.691668267706"/>
		<point f="861.454478130761" d="-6.336655832309"/>
		<point f="896.260925544827" d="-5.981682344187"/>
		<point f="932.473702384699" d="-5.642743688705"/>
		<point f="970.149630377408" d="-5.332939668016"/>
		<point f="1009.347827090922" d="-5.052270282123"/>
		<point f="1050.129798695936" d="-4.800735531023"/>
		<point f="1092.559536475655" d="-4.578335414719"/>
		<point f="1136.703617234967" d="-4.388720609166"/>
		<point f="1182.631307766587" d="-4.262936692435"/>
		<point f="1230.414673538071" d="-4.208055049372"/>
		<point f="1280.128691770264" d="-4.221220544422"/>
		<point f="1331.851369084591" d="-4.293011444200"/>
		<point f="1385.663863903797" d="-4.422735490879"/>
		<point f="1441.650613798221" d="-4.611609426064"/>
		<point f="1499.899467977380" d="-4.867386265049"/>
		<point f="1560.501825134801" d="-5.191436659110"/>
		<point f="1623.552776862353" d="-5.600535276583"/>
		<point f="1689.151256859160" d="-6.117062241804"/>
		<point f="1757.400196169156" d="-6.717146730572"/>
		<point f="1828.406684690938" d="-7.355813158095"/>
		<point f="1902.282139213286" d="-7.812561327004"/>
		<point f="1979.142478240037" d="-8.057797608654"/>
		<point f="2059.108303878647" d="-8.091522003043"/>
		<point f="2142.305091077818" d="-7.913734510172"/>
		<point f="2228.863384511134" d="-7.524435130041"/>
		<point f="2318.919003415637" d="-6.984213921538"/>
		<point f="2412.613254706779" d="-6.375635660368"/>
		<point f="2510.093154704097" d="-5.701668113256"/>
		<point f="2611.511659815581" d="-4.984351889985"/>
		<point f="2717.027906542657" d="-4.203755352873"/>
		<point f="2826.807461182420" d="-3.361971843810"/>
		<point f="2941.022579618894" d="-2.539133580825"/>
		<point f="3059.852477610953" d="-1.776227979000"/>
		<point f="3183.483612001085" d="-1.079108352158"/>
		<point f="3312.109973286116" d="-0.455562256503"/>
		<point f="3445.933390009112" d="0.111891361228"/>
		<point f="3585.163845449983" d="0.624155963216"/>
		<point f="3730.019807111749" d="1.100914198321"/>
		<point f="3880.728569519447" d="1.550181281231"/>
		<point f="4037.526610869621" d="1.978742246349"/>
		<point f="4200.659964089935" d="2.399325435265"/>
		<point f="4370.384602891188" d="2.788400166859"/>
		<point f="4546.966843417520" d="3.145966441131"/>
		<point f="4730.683762124962" d="3.472024258082"/>
		<point f="4921.823630544081" d="3.766573617711"/>
		<point f="5120.686367608909" d="4.024473938388"/>
		<point f="5327.584010261886" d="4.249179726607"/>
		<point f="5542.841203073237" d="4.444512273164"/>
		<point f="5766.795707643121" d="4.610471578059"/>
		<point f="5999.798932585757" d="4.747057641292"/>
		<point f="6242.216484927173" d="4.854270462863"/>
		<point f="6494.428743781841" d="4.930522577626"/>
		<point f="6756.831457208243" d="4.978583382957"/>
		<point f="7029.836363179988" d="4.999153036092"/>
		<point f="7313.871835646775" d="4.992231537030"/>
		<point f="7609.383556699107" d="4.957818885772"/>
		<point f="7916.835215891137" d="4.895915082318"/>
		<point f="8236.709237819316" d="4.801124311446"/>
		<point f="8569.507539098324" d="4.673421289623"/>
		<point f="8915.752315921907" d="4.514209810480"/>
		<point f="9275.986863444756" d="4.336806012751"/>
		<point f="9650.776428270770" d="4.159299795052"/>
		<point f="10040.709095385559" d="3.981793577354"/>
		<point f="10446.396710924804" d="3.804287359655"/>
		<point f="10868.475842226373" d="3.626781141956"/>
		<point f="11307.608776672689" d="3.449274924258"/>
		<point f="11764.484560890680" d="3.271768706559"/>
		<point f="12239.820081939626" d="3.094262488861"/>
		<point f="12734.361192183844" d="2.924753725134"/>
		<point f="13248.883879615034" d="2.764301017958"/>
		<point f="13784.195485460406" d="2.603848310783"/>
		<point f="14341.135970987791" d="2.441793574762"/>
		<point f="14920.579235494641" d="2.259386003328"/>
		<point f="15523.434487549899" d="2.051233360653"/>
		<point f="16150.647671639461" d="1.811122139457"/>
		<point f="16803.202952454511" d="1.521653799616"/>
		<point f="17482.124259151475" d="1.200677002453"/>
		<point f="18188.476892006398" d="0.856520692338"/>
		<point f="18923.369193985294" d="0.559470809758"/>
		<point f="19687.954289853158" d="0.325437841822"/>
		<point f="20483.431895550038" d="0.154421788529"/>
		<point f="21311.050200674003" d="0.046422649880"/>
		<point f="22172.107827024505" d="0.001440425874"/>
		<point f="23067.955866278819" d="0.000000000000"/>
		<point f="24000.000000000018" d="0.000000000000"/>
	</curve>
Post by kozikowski » Fri Jun 13, 2008 12:51 am
Goodness.
I'm out of breath. I'll have to sit down for a minute.
Post by steve » Fri Jun 13, 2008 10:14 am
kozikowski wrote:....I want pinstripes inside the equalizer work window to tell me where I am. Quick, point to a place 4 dB down at 7500 Hz.
I've been thinking about this suggestion every time I use the Equalization effect (and the "plot spectrum") and yes I agree, a "graph paper background" would be very handy. It would be nice if the background could be toggled on/off.
