all in the same level
willemijns
Post by willemijns » Wed Apr 30, 2008 11:37 pm
hello,
I have grabbed for an internet website a sound but sound seems bad, how to downgrade to stay on the same level these 2 sounds ?
http://img504.imageshack.us/img504/6605/problemeew1.png
thanks of your answer(s).
Re: all in the same level
Post by kozikowski » Thu May 01, 2008 7:35 am
You have several problems with those cuts.
First, I would convert my timeline to dB so all the tools are operating in the same standard.
Black arrows on the left > Waverform (dB)
Then grab the bottom of the timeline and pull down so you can see what you're doing.
http://kozco.com/tech/audacity/AudacityPanelFull.jpg
And last, the level problem and the DC problem should respond to
Edit > Select > All
Effect > Normalize
Normalize to -3 and Remove DC which is the default for Audacity 1.2
willemijns
Post by willemijns » Thu May 01, 2008 9:09 am
hi kozco,
thanks of your answer but i haven't understood this:
can you (or another ppl) can more explain ? ;)
cya
Post by kozikowski » Fri May 02, 2008 5:55 pm
That dB thing is less important than getting the other tools to work. Can you find the "Normalize" tool and make it work?
Edit > Select > All
Effect > Normalize
