NTSC frames
susanalic
Re: NTSC frames
Post by susanalic » Tue Apr 29, 2008 8:06 pm
Thats what I referred to appdata; I also removed it.
http://rapidshare.com/files/111352682/audacity.cfg.html
Re: NTSC frames
Post by steve » Wed Apr 30, 2008 5:04 pm
Try this version (after completely removing your existing version)
http://easyspacepro.com/audacity/audaci ... -1.3.4.exe
susanalic
Re: NTSC frames
Post by susanalic » Wed Apr 30, 2008 6:06 pm
No lucky, 29000
Re: NTSC frames
Post by steve » Wed Apr 30, 2008 11:19 pm
In that case I definately can't help you - that is the exact same installation file that I used for installing Audacity on my XP machine. There must be something (hardware or software) about your computer that is messing it up. It's quite ironic that you are one of the few people that want to use this feature, and it doesn't work on your machine.
The only solution that I can think of (short of getting another computer or re-installing Windows) is to use Linux. I don't know if you want to go that far with it, but it would be an interesting experiment to try running Audacity from the Live CD version of DSL http://www.damnsmalllinux.org/ (or any other Live CD Linux)
susanalic
Re: NTSC frames
Post by susanalic » Thu May 01, 2008 8:42 am
Thank you very steve.
Actually I need 23.976 fps :)
I've read there are some differences in european windows xp, maybe it's related. For example, I cannot use latest versions of muxman (an authoring tool) for this reason (for it and that the devoloper doesn't fix this yet).
