Hi all,
I've been trying to figure out a way to combine wav files from the command line with audacity, but it doesn't seem possible. I found SOX, but it's not working for me correctly (I am spawning it from a server side language, ColdFusion, and it doesn't work consistently and sometimes doesn't release itself from memory properly when it completes).
Does anyone know of another command line utility that will do this? I'm really looking for something with a small footprint and simple, but will look at anything that can do it at this point.
Thanks!
Dave
Combining wav files from command line
davephillips
Re: Combining wav files from command line
<<<command line utility >>>
It would probably be good to know the operating system providing the command line.
