Noise Removal Tests
Re: Noise Removal Tests
Permanent link to this post Posted by steve » Mon Oct 10, 2011 6:50 pm
Gale Andrews wrote:I'm a bit concerned with yet another effect to try and get your noise removed whereas most software only has one effect. How many controls does noise coring have? I never tried the patch.
It's still quite early days for the Noise Coring effect.
Currently there are 4 controls, two of which set the "noise profile", 1 sets the FFT size (which can probably be fixed as the default seems to work well with everything), and the 4th slider sets the amount of reduction. If the effect used a "Get Noise Profile" method, then the number of controls could probably be reduced to just one slider, or even be completely automatic.
If this effect was separate from the Noise Removal effect, then I'd suggest calling it "Hiss Removal" (or something similar), and for users it could be a much simpler option than "Noise Removal".
Alternatively it could perhaps be included in the current Noise Removal effect.
The Noise Coring effect is only suitable for broadband noise (hiss), but that is a very common type of noise, and this effect looks like it will be highly effective and simple to use.
I'll post again when there's more news.
Extra noise/filter plugins
Permanent link to this post Posted by Gibbz » Tue Jul 11, 2017 8:51 am
There are a few great looking noise filters ive seen that look like they got stuck in development.
Im wondering when these are likley to make it in to audacity?
Or if there is a way to get a build with these already implemented?
These two:
Noise Coring
http://wiki.audacityteam.org/wiki/Propo ... ise_Coring
( https://forum.audacityteam.org/viewtopi ... 9&start=50 )
( http://audacity.238276.n2.nabble.com/No ... 55895.html )
Spectral Subtraction
http://wiki.audacityteam.org/wiki/Propo ... ubtraction
Gibbz
Operating System: GNU/Linux other
Permanent link to this post Posted by Gibbz » Tue Jul 11, 2017 8:54 am
Any updates on the progress of this noise coring?
Gibbz
Permanent link to this post Posted by Gale Andrews » Tue Jul 11, 2017 12:57 pm
Gibbz wrote:Any updates on the progress of this noise coring?
Please stop making similar posts in different topics. They only have to be moved by a moderator ;)
Permanent link to this post Posted by steve » Tue Jul 11, 2017 1:15 pm
Unfortunately we've not heard from Jérôme M. Berger for several years, so until unless developer decides to continue that project we are not going to see it progress.
Permanent link to this post Posted by jmb » Sat Apr 07, 2018 1:25 pm
Noise coring is now available as a LADSPA plugin here: https://bitbucket.org/jmb/ladspa-noisecoring/
jmb
Permanent link to this post Posted by steve » Sun Apr 08, 2018 6:29 pm
Hi Jérôme, nice to hear from you again :)
I've just downloaded the Linux build, and from a quick initial test it looks very impressive.
Could I suggest that you start a new topic for your new LADSPA plug-in (new topics tend to get more attention than old threads).
Previous
Return to Audio Processing
Who is online
Users browsing this forum: No registered users and 8 guests
