Hey Advice for removing a sound please
ThomasP
Post by ThomasP » Mon Aug 30, 2010 2:18 pm
Hey would anyone mind helping remove a sound from one of my sound files ?
The sound only has one channel and sounds like a metal against wood clicking sound.
So far I tried the 'Click remover' plugin and didn't work. The best I can do is delete the small section of the graph that makes that sound.. but it doesn't blend very well.
How could I make this blend well so no one would notice ?
Regards
Thomas
Re: Hey Advice for removing a sound please
Post by steve » Mon Aug 30, 2010 2:30 pm
Have you tried the "Repair" effect?
BTW, which version of Audacity are you using?
Trebor
Post by Trebor » Mon Aug 30, 2010 6:20 pm
ThomasP wrote: The best I can do is delete the small section of the graph that makes that sound.. but it doesn't blend very well.
Could try using "Repair" (in Audacity "Effect" menu) on the join where you have deleted the bit from the "graph" (a.k.a. waveform).
Post by steve » Mon Aug 30, 2010 6:27 pm
Trebor wrote:Could try using "Repair" (in Audacity "Effect" menu) on the join where you have deleted the bit from the "graph" (a.k.a. waveform).
or if it's a small click (less than 128 samples) just apply the Repair effect to the click.
Trebor
Post by Trebor » Mon Aug 30, 2010 7:05 pm
Sorry Steve I didn't see your post suggesting "Repair", (I need new glasses :geek: ).
Post by steve » Mon Aug 30, 2010 7:54 pm
No problem Trebor. If the clicks are too long for "Repair" then your suggestion of cutting out the click manually and then applying Repair to where the edit was made will do the trick.
ThomasP
Post by ThomasP » Tue Aug 31, 2010 1:59 am
It blends together much nicer now with "Repair" - Thanks guys
