PDX:pdxrunner wrote:
Specifically what I do after doing the noise sample, is turn noise-only sound on, crank the output volume way up, and restart deNoise. I listen for anything musical or rhythmic mixed in with the noise, and adjust the noise-floor slider until I can barely hear any noise. I'll check what's getting removed visually by pausing the tool and looking at the display. You really have to read and understand the deNoise manual to make sense of the display. Once I'm satisfied with the settings, I restart the tools without changing any settings. Throughout, I almost always have "Limit Reduction" slider at 9 dB (default was 12 IIRC)
PDX
A couple of questions about your technique:
1: You state "You really have to read and understand the DeNoise Manual to make sense of the display". I notice that most of the application's screen space is devoted to Davies' graphs. This is quite different than Audacity, where I pay attention only to the Waveform left and right channels. Do you adjust your Davies' settings PURELY based on your ear, or do you in fact let what your eyes see in Davies' graphs affect your settings?
Offhand, the graphs seem to be a distraction and waste of screen space, to the extent that slider settings and button choices are ultimately driven by ear not eye. I don't want to get bogged down in trying to make sense of the graphs by eye if in the real world the ear controls all and over-rides the eye.
It appears you operate by ear not eye as well? Do you ever adjust anything based on what you see as opposed to what you hear?
2: You state that you leave the limit reduction set at 9, not the default 12. I am guessing this control is very similar if not identical to the "Noise Reduction (db)" slider in Audacity's NR menu? In Audacity, I leave this at the default 12 well over 90% of the time. I will occasionally set it higher for a particularly rough 78. And I will occasionally do one pass at 12 and a second pass at 12 or less. You may be enough younger than I that your ears can detect unwanted effects with a slider at 12 that I cannot detect.
As an aside:
In Audacity, do any of you typically set the other 2 NR sliders (frequency smoothing and attack/decay time) at anything other than defaults? I have done very very little experimentation with these sliders.
Any further comments appreciated.
