Effects always stop at 0:35
smeezekitty
Post by smeezekitty » Mon Jul 19, 2010 7:12 pm
When ever i select the whole file and apply an effect, it almost always stops at 35 seconds and the selection collapses to 0:35.
Whats with that?
billw58
Re: Effects always stop at 0:35
Post by billw58 » Mon Jul 19, 2010 7:28 pm
Could you be more specific? What computer and OS, which version of Audacity, how many tracks in the project, and which effects specifically? You say "almost always" - is it dependent on the effect used, the number of tracks in the project, or some other condition?
-- Bill
smeezekitty
Post by smeezekitty » Mon Jul 19, 2010 8:16 pm
billw58 wrote:Could you be more specific? What computer and OS, which version of Audacity, how many tracks in the project, and which effects specifically? You say "almost always" - is it dependent on the effect used, the number of tracks in the project, or some other condition?
-- Bill
Its windows vista with audacity 1.2.6, the sound file is two tracks and 6:30 long.
It does this on almost any sound file but occasionally it works perfectly, dependent on the file and if it decides to i guess.
All effects do the same, (pitch, speed, echo, etc)
Post by steve » Mon Jul 19, 2010 11:17 pm
Audacity 1.2.6 is known to be very buggy on Vista.
Try Audacity 1.3.12 and see if you still have a problem.
smeezekitty
Post by smeezekitty » Wed Jul 21, 2010 2:05 am
Fixed.
