removing chirps from guitar recording
johnnydoxx
Re: removing chirps from guitar recording
Post by johnnydoxx » Wed Mar 19, 2008 9:14 pm
Man - you guys are really energetic. Appreciate the responses. I managed to work around it good enough for my purposes.
I bought a 20-foot extension cord for the mike and another for my earphones. I put the mike in the far corner of the room and stepped back into the other corner, almost out the door. Then I used a medium-thickness pick, which makes a pretty loud guitar in that room. This made the guitar loud compared to the chirps (oh, a good listener/picker, or someone to whom they are pointed out, can hear them, but they are under a normal listener's radar). I then used the Db control when mixing the final deal, turning the guitar down some compared to the vocals.
So with that set-up, I'm OK with the result. Again, thanks for all the responses and suggestions. They helped narrow down the options for solving this. I don't want to take any more of anyone's time on this.
If I ever get nerve enough to post a song to one of the hosting sites, I'll send a link to it, so you can hear the result.
The software is just what I needed - so I can play the guitar with full concentration and then add vocals, without having to get both correct in one take. Thanks to the gurus for making it available.
waxcylinder
Post by waxcylinder » Thu Mar 20, 2008 11:11 am
Johnny,
What you are learning is that MIC placement is a great art - and has a big impact on the recorded sound.
MICing that is too close to the source drives me crazy sometimes on commercial recordings. Example: I have an otherwise excellent recording of the Mozart clarinet quintet which when I listen to on my Quad ELS loudspeakers (very detailed speakers) the sound is totally marred by the clattering of the clarinet keys closing - and I do mean clattering, it's like someone shaking a can full of nails/screws ........
Good luck with your music - and keep practising on that guitar .......
