dr_flam wrote:
*How did you derive the different lines? Only drawn by hand?
Yes, drawn by hand.
dr_flam wrote:*What do you have on the y axis?
The y axis is a linear scale +/- 1.0 (the default "waveform" view).
If you want the read-out in dB, click on the track name and select "Waveform dB".
The relationship between the linear scale and dB (approximately)
+/- 1.0 = 0dB
+/- 0.5 = -6dB
+/- 0.25 = -12dB
+/- 0.125 = -18dB
+/- 0.0625 = -24dB
dr_flam wrote:*What would be in this example the duration of the sustain?
If you're talking about ADSR envelopes, it is zero, but that's not very useful for your purposes.
For measuring the sustain of a drum, it would be more useful to decide on what level you are going to consider to be "silence" (if you had an infinitely sensitive microphone and no other noise, the drum would probably ring forever, but at a very very very low level).
You will probably find it most convenient to use the "Silence Finder" tool (in the "Analyze" menu) to mark the point at which the sound becomes "silent".
Let's say that you decide that -24dB is close enough to silence, use the Silence Finder tool and set the first slider to -24 and the other 2 sliders to minimum.
It would probably be interesting compare the "sustain" (how long it rings) with/without damping rings using different "threshold" settings (the first slider), that way you will be able to see how much the rings affect the decay from peak to -6/-12/-18/-24/-48 dB which will show how the damping effect varies over time/amplitude. I would expect the damping effect from peak to -24dB to be a much greater difference than the damping effect from peak to -6dB.
I would be interested to know how you get on with this - your results/conclusions.
