cd burning?
waxcylinder
Re: cd burning?
Post by waxcylinder » Fri Jul 02, 2010 4:10 pm
I've never had problems with Nero - I used to use Nero that came bundled on one of my earlier PCs and it always produced good CDs (data and music) and it was easy enough to use.
I now use Nero-9, but mainly for simple video editing and DVD burning - it does that job well and straightforwardly too (in fact my Audacity editing skills reduced the Nero video editing learning-curve somewhat). I have also used this Nero-9 to burn CDs and that is simply done and also works well.
whomper
Probationer
Re: cd burning?
Post by whomper » Fri Jul 02, 2010 4:31 pm
if you only do basic things nero works but is awkward to find where everything is . it has a poor and irrational user interface that was quick to code but hard to use.
latest nero on my new pc defaults to a screen size that is 4x the real size and there are no scroll bars
its arrogant - do it their way or dont use it at all
nero defaults to the wrong options
and wont let you lock them donw
have to find them every time and change them again
nero is fussy about the blank cds you use
has problem at times with data on vendor x and music on vendor y
PITA to keep them straight to know what combos work
Nero wont coexist with any other burner program
install roxio and neither of them will work
you have to rip nero out by the roots first
not that roxio is any better
but last 3 pcs only had nero so i try to use it
until i spring for cd architect
now maybe nero big full paid edition removes the problems
but i am not going to spend money on it to hope that it did
Re: cd burning?
Post by kozikowski » Sun Jul 04, 2010 7:07 pm
<<<nero is fussy about the blank cds you use >>>
It's not Nero. These are all the problems I used to have on a really old PC. Everything was critical and I had to be really careful which kinds of disks I used and the burn speed and other settings. I also had enormous problems with the free Nero that vanished with the paid version. All the other problems vanished with a faster PC with better drive management.
Re: cd burning?
Post by steve » Sun Jul 04, 2010 9:11 pm
whomper wrote:if you only do basic things nero works but is awkward to find where everything is .
The full interface may be a little intimidating for novice users because it includes support for many advanced formats and features: multiple drive support, multiple copies, data verification, bootable CD support, mixed mode CDs and other advanced features. However they also include an "idiot-proof mode" (or whatever they call it) - a "wizard" that takes you through burning standard ISO or audio CDs in a simple step-by-step fashion.
whomper wrote: latest nero on my new pc defaults to a screen size that is 4x the real size and there are no scroll bars
Perhaps you would have been better with Nero 9. The display requirements for Nero 9 are: Graphics card with at least 32 MB video memory and minimum resolution of 800 x 600 pixels and 16-bit color settings (24-bit or 32-bit true color is recommended)
whomper wrote:its arrogant
because they don't do it your way? Most software, in fact most tools of any kind need to be used correctly for best results.
whomper wrote:nero defaults to the wrong options
I would prefer to be able to set the default CD type to "Audio CD" instead of "ISO data CD", but most other options are configurable.
whomper wrote:nero is fussy about the blank cds you use
That's down to the CDs and the CD burning hardware rather than the software. Nero is able to auto-detect the speeds that the CD manufacturers claim are supported. It defaults to the maximum supported write speed but also allows the user to select any of the supported speeds for the CD that is in the selected drive(s). It also has a feature (enabled by default) that checks the speed at which data is actually being written by the drive, and automatically slows down if the disk cannot be written to at the claimed speed. This latter feature reduces the number of coasters dramatically compared to CD burning software that does not have this.
Nero also includes a comprehensive set of tools to test and optimise CD writing quality. Of course users do not necessarily use the provided tools.
whomper wrote:Nero wont coexist with any other burner program
Rubbish. I use both Nero and CDBurnerXP on many PCs.
whomper wrote:now maybe nero big full paid edition removes the problems
Not surprisingly, considering that Nero is a commercial product, the free versions do not measure up to the full product.
Nero provide a free "Lite" version of Nero 9, though I'd rather recommend my favourite free CD burning application for Windows - CDBurnerXP. It is simple to use and has many features, though it does lack a few advanced features that are available with the full version of Nero (which is unlikely to be a drawback for most users).
Personally my favourite CD burning application is K3B, but that is not available for Windows or Mac (it's a Linux application).
bgravato
Re: cd burning?
Post by bgravato » Sun Jul 04, 2010 11:18 pm
stevethefiddle wrote:The full interface may be a little intimidating for novice users because it includes support for many advanced formats and features: multiple drive support, multiple copies, data verification, bootable CD support, mixed mode CDs and other advanced features. However they also include an "idiot-proof mode" (or whatever they call it) - a "wizard" that takes you through burning standard ISO or audio CDs in a simple step-by-step fashion.
It's those wizards that turn me off... Feels awkward and not very intuitive for me... But then I'm not the typical regular user...
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
