Is it possible to remove distortion?
whomper
Probationer
Re: Is it possible to remove distortion?
Post by whomper » Thu Jun 24, 2010 5:22 pm
Twinsfan1 wrote:...
The sound guy is a 16-year-old kid, who's heart is huge. The other sound guy ... has figured out how to avoid the distortion, so ...he will show this guy how to do it. In the meantime I'll ask him what he's doing and maybe I can show our sound guy.
He is teachable - .... Besides, his dad is the vice-chairman ... If I fire his son, then my next board meeting will be, shall we say, a bit uncomfortable concerning my job security.
Actually, that's not true - he's a great guy and our church board isn't that petty....
The solution seems to be in avoidance, not in clearing up existing files. ...
You implied he was not teachable. If he really is then just have someone show him what to do. Run some test sessions to be sure he understands it. I would be more worried about him blowing a speaker by turning the phantom on in the wrong sequence than some distortion.
Maybe you all need one of those books on how to do sound for a church that instructs the average guy about what to do. There are more problems lurking.
Unless this is a real job with a megachurch you should not worry or care about what anyone else thinks about the sound. If you do what needs to be done be happy. If they fire you anyway be happier. And if this is a real job then you all need to get your act together before your next check is deposited.
AAmazing. Most churches are rife with petty politics.
As well as many other contradictory characteristics.
Yes. WRT distortion you have to avoid it.
In theory , with enough money, you can take a digital photo that is out of focus and correct it. But you cant take one that is overexposed and fix it. Underexposed - yes to some extent but with a lot of noise. Not sure what the analogs are but I would link clipping to overexposure. Not going to fix it. Distortion to out of focus - fixable in theory but only if you can print money like the feds do.
Twinsfan1
Post by Twinsfan1 » Thu Jun 24, 2010 5:30 pm
I didn't mean to imply the young man wasn't teachable. Please accept my apology for any confusion.
We are all newbies - started recording just over a year and a half ago. We're using my laptop connected to our very small and very basic sound board.
We are a small church and don't have the budget for a newer or bigger sound system. Other than this problem, we're doing okay for our size.
Thanks for the input!
Brian
whomper
Probationer
Post by whomper » Thu Jun 24, 2010 5:40 pm
maybe i inferred instead of your implying.
heart of gold not withstanding, many such folks do the best job of making schlemazzels out of us.
everybody was new once. some people want to learn.
some think they know everything. some want to experiment at the wrong times.
In a year and a half everyone should have figured out how to do the levels.
You dont need a lot of fancy gear. Just know how to use what you have correctly.
Many churches are small these days. Instead of having one every couple of blocks I wish some would merge and get to critical mass to be able to do things better.
We have a basic sound board that was donated by a dj. We use a wireless mike for one input. We output to a recorder in mp3 to ensure we dont run longer than a CD's 79-80 minute limit.
A snake is permanently in place for the mikes. One for the stage and one for the piano. Ability to add a few more by plugging into the snakehead when needed. Second output to the power amp for sound reinforcemetn (not PA type).
Really not complicated as noted in the previous message.
Know how to power it all on/off correctly and check the settings versus a sheet that shows where everything should be. Then at most tweak one mike gain if someone else is louder/softer than the usual suspects (pastor and pianist).
I seriously suggest you all get a couple of basic books on this and read them.
whomper
Probationer
Post by whomper » Thu Jun 24, 2010 5:43 pm
kozikowski wrote:Since the performer is generally paid far more and or have higher stature than the sound guy, the sound guy would go in favor of one that knew how to record live performances. It's far more difficult than anyone thinks.
Paid performers? Don't know what church you go to. A few megachurches may pay, but most everything I have seen is free all around , sometimes even the pastor. National cathedral in DC has a paid choir. Most in the burbs are lucky to have a free choir. Many have none.
Yes and no. Live sound can be difficult for something like a Gloria Estefan tour set up with monitors, wireless mikes, multiple mikes, compression, eq, f/x, lighting, yada yada. But in a fixed setting like a church it is usually possible to set it up so that it is not that hard for basic audio. Mega churches with the full audio video lighting etc are more like a touring company.
We use a couple of volounteers. All they have to do is get the power on without blowing out the speakers. Check the faders and knobs to make sure the Koreans renting space didn't change them the night before. Then just turn on the recorder. Optionally they may need to plug in another mike to the snakehead if there is a soloist. The asst pastor's wife does it often and she is a nurse not an audio whiz.
Post by kozikowski » Thu Jun 24, 2010 6:26 pm
<<<Paid performers? Don't know what church you go to.>>>
"Or have higher stature..." Don't cherry pick.
"Simple audio recordings" are usually nothing of the sort. Without basic audio chops, all sorts of things can go wrong. We will be walking into a training session this afternoon with a presenter, camcorder and a display monitor. This will be the third time someone has tried to record a simple lecture and we hope third time's a charm. The first two capture sessions have been disasters for one reason or another -- in one case, nobody could hear the presenter. That's when they called me.
This is harder than it looks, particularly is nobody on the "crew" has any technical background.
Someone pointed me to a ministry presentation from, I think the Bahamas, and the whole hour was in clipping distortion. It was, in fact, better than nothing.
Post by steve » Thu Jun 24, 2010 6:31 pm
Twinsfan1 wrote:The solution seems to be in avoidance, not in clearing up existing files.
That's the general idea ;)
In case you missed it amongst the sudden flurry of posts, the post by billw58 has some very good practical tips. All but the very smallest mixer boards have a "gain" (sometimes called a "trim") control, which is usually very close to where the microphones plug in. They then have a "fader" for controlling the output level for that sound channel - on mid-size and large mixer boards this is usually a slide fader, but on some small mixers it can be another rotary control. Getting the "Gain" level right is important as if the sound distorts at the begining of the signal chain it will be distorted all the way through to the final recording. If the gain is a lot too low, then the volume level on everything else will be pushed up to the max and you will struggle to get a strong enough signal out. When setting levels, start with everything at minimum (avoids blowing the speakers) then work from the source (the microphones) along the signal chain to the output, setting the levels carefully at each step.
whomper
Probationer
Post by whomper » Thu Jun 24, 2010 7:02 pm
can KIAs screw up - sure all the time
can naive people not see the pitfalls - of course
are bad recordings the norm with noobs - you betcha
but is basic recording that hard? absolutely not
are people idiots AND never RTFM - world is full of them
do big shows need a professional crew - absolutely
do little churches need more than a willing volounteer - nope
-- not if he is willing to listen and learn and perhaps read a basic book
YMMV but that is my experience
whomper
Probationer
Post by whomper » Thu Jun 24, 2010 7:13 pm
stevethefiddle wrote:
Twinsfan1 wrote:... If the gain is a lot too low, then the volume level on everything else will be pushed up to the max and you will struggle to get a strong enough signal out. ....
and too low may be noisy. but choose some noise over distortion.
you can clean up noise somewhat. you cant really fix distortion.
whomper
Probationer
Post by whomper » Thu Jun 24, 2010 7:21 pm
kozikowski wrote:....
I must respectfully disagree. No recording with clipping distortion is better than nothing. I would absolutely refuse to listen to it, even if getting paid to master it I would send it back with their check and just say no way.
My one exception would be for certain recordings that are about 2010 years old +5/- 15 years. For that I would make the effort to listen and capture a transcription.
Most teleprechears have decent audio. The ones that dont record themselves and often broadcast on some shortwave radio station.
Most commercial stations wont allow such bad programming even if paid.
Not on our cable anymore but there is one in the LA/Pasadena area that features 12-15 performers that has excellent audio. All using SM58s for each singer, drums, guitar, bongos, electric keyboard, and piano.
billw58
Post by billw58 » Thu Jun 24, 2010 9:51 pm
stevethefiddle wrote:When setting levels, start with everything at minimum (avoids blowing the speakers) then work from the source (the microphones) along the signal chain to the output, setting the levels carefully at each step.
Not exactly what I was saying. Hopefully there is a "monitor" level control that controls the level sent to the speakers. By all means set it to minimum. Also set the trim control to minimum. But you need the channel and master faders at nominal positions in order to see when you've got the trim level right. Watch the meters and slowly turn up the trim control with someone speaking loudly. Then you can turn up the monitor control to set the loudness in the room.
Some mixers have a pre-fader clip light on each channel. You can use that to set the trim, but it can involve a bit of guesswork in determining how far to turn down the trim control after the clip light lights up.
But it seems the OP is not using a sound system, simply recording the proceedings - no speakers or eardrums to blow.
-- Bill
