Submit your EQ Curves
Re: Submit your EQ Curves
Permanent link to this post Posted by fellegis » Tue Apr 05, 2016 11:15 pm
Normal audio casettes response:
Code: Select all
<equalizationeffect>
   <curve name="BASF FE L90">
      <point f="50" d="-0.9"/>
      <point f="315" d="2.8"/>
      <point f="1000" d="2.8"/>
   </curve>
   <curve name="BASF FE L100">
      <point f="50" d="-0.5"/>
      <point f="315" d="3.3"/>
      <point f="1000" d="3.5"/>
   </curve>
   <curve name="TDK AR 90">
      <point f="50" d="3.2"/>
      <point f="315" d="6.4"/>
      <point f="1000" d="5.1"/>
   </curve>
   <curve name="TDK AR 100">
      <point f="50" d="2.8"/>
      <point f="315" d="5.3"/>
      <point f="1000" d="4.1"/>
   </curve>
   <curve name="BASF CE 90">
      <point f="50" d="-1.7"/>
      <point f="315" d="2.2"/>
      <point f="1000" d="0.5"/>
   </curve>
   <curve name="BASF CE 100">
      <point f="50" d="-1.9"/>
      <point f="1000" d="0.4"/>
   </curve>
   <curve name="Denon HD6 90">
      <point f="50" d="-2.8"/>
      <point f="315" d="0.7"/>
      <point f="1000" d="-0.2"/>
   </curve>
   <curve name="Denon HD6 100">
      <point f="315" d="2.0"/>
      <point f="1000" d="1.0"/>
   </curve>
   <curve name="Denon HD8 90">
      <point f="50" d="-0.6"/>
      <point f="315" d="3.1"/>
      <point f="1000" d="2.1"/>
   </curve>
   <curve name="Denon HD8 100">
      <point f="50" d="-1.1"/>
      <point f="315" d="2.1"/>
      <point f="1000" d="0.9"/>
   </curve>
   <curve name="Maxell XLII 90">
      <point f="50" d="-3.4"/>
      <point f="315" d="1.2"/>
      <point f="1000" d="0.2"/>
   </curve>
   <curve name="Maxell XLII 100">
      <point f="50" d="-2.9"/>
      <point f="315" d="1.0"/>
   </curve>
   <curve name="Maxell XLII-S 90">
      <point f="50" d="-3.3"/>
      <point f="315" d="0.1"/>
      <point f="1000" d="-0.4"/>
   </curve>
   <curve name="Maxell XLII-S 100">
      <point f="315" d="0.0"/>
      <point f="1000" d="-0.5"/>
   </curve>
   <curve name="Memorex HBS-II 90">
      <point f="50" d="-3.0"/>
      <point f="315" d="0.5"/>
   </curve>
   <curve name="Memorex HBS-II 100">
      <point f="50" d="-3.5"/>
      <point f="315" d="0.6"/>
      <point f="1000" d="0.0"/>
   </curve>
   <curve name="TDK SA 90">
      <point f="50" d="-1.4"/>
      <point f="315" d="2.3"/>
      <point f="1000" d="1.3"/>
   </curve>
   <curve name="TDK SA 100">
      <point f="50" d="-2.1"/>
      <point f="315" d="1.4"/>
   </curve>
   <curve name="Denon HD-M 90">
      <point f="50" d="1.6"/>
      <point f="315" d="5.7"/>
      <point f="1000" d="4.7"/>
   </curve>
   <curve name="Denon HD-M 100">
      <point f="315" d="5.8"/>
   </curve>
   <curve name="Maxell MX 90">
      <point f="50" d="1.2"/>
      <point f="315" d="4.9"/>
   </curve>
   <curve name="Maxell MX 100">
      <point f="50" d="1.1"/>
      <point f="315" d="5.1"/>
      <point f="1000" d="5.0"/>
   </curve>
   <curve name="TDK MA 90">
      <point f="50" d="1.9"/>
      <point f="315" d="5.9"/>
      <point f="1000" d="6.1"/>
   </curve>
   <curve name="TDK MA 110">
      <point f="50" d="2.0"/>
   </curve>
</equalizationeffect>
BASF studio master 468:
Code: Select all
   <curve name="BASF Studio Master 468 76.2 cm/s">
      <point f="10000" d="1.5"/>
      <point f="16000" d="2.5"/>
   </curve>
   <curve name="BASF Studio Master 468 38.1 cm/s">
      <point f="16000" d="1.5"/>
   </curve>
   <curve name="BASF Studio Master 468 19.05 cm/s">
      <point f="12500" d="1.5"/>
   </curve>
RMG Studio tapes:
Code: Select all
   <curve name="RMG Studio Master SM911 76.2 cm/s">
      <point f="1000" d="1.5"/>
   </curve>
   <curve name="RMG Studio Master SM911 38.1 cm/s">
      <point f="10000" d="2.5"/>
      <point f="16000" d="3"/>
   </curve>
   <curve name="RMG Studio Master SM911 19.05 cm/s">
      <point f="1000" d="1"/>
      <point f="10000" d="0.5"/>
      <point f="12500" d="0.5"/>
   </curve>
   <curve name="RMG PER528 76.2 cm/s">
      <point f="1000" d="0"/>
      <point f="10000" d="1"/>
   </curve>
   <curve name="RMG PER528 38.1 cm/s">
      <point f="16000" d="1"/>
   </curve>
   <curve name="RMG PER528 19.05 cm/s">
      <point f="10000" d="2"/>
      <point f="12500" d="2"/>
   </curve>
fellegis
Operating System: GNU/Linux other
Permanent link to this post Posted by fellegis » Sat Apr 09, 2016 8:34 pm
Sound absorptions:
Code: Select all
   <curve name="Absorption: Brick Unglazed">
      <point f="125.000" d="-0,132283"/>
      <point f="250.000" d="-0,132283"/>
      <point f="500.000" d="-0,132283"/>
      <point f="1000.000" d="-0,177288"/>
      <point f="2000.000" d="-0,222764"/>
      <point f="4000.000" d="-0,315171"/>
   </curve>
   <curve name="Absorption: Brick Unglazed, Painted">
      <point f="125.000" d="-0,043648"/>
      <point f="250.000" d="-0,043648"/>
      <point f="500.000" d="-0,087739"/>
      <point f="1000.000" d="-0,087739"/>
      <point f="2000.000" d="-0,087739"/>
      <point f="4000.000" d="-0,132283"/>
   </curve>
   <curve name="Absorption: Carpet Heavy, on Concrete">
      <point f="125.000" d="-0,087739"/>
      <point f="250.000" d="-0,268721"/>
      <point f="500.000" d="-0,655015"/>
      <point f="1000.000" d="-2,006595"/>
      <point f="2000.000" d="-3,979400"/>
      <point f="4000.000" d="-4,559320"/>
   </curve>
   <curve name="Absorption: Carpet Heavy, on 40oz Hairfelt or Foam Rubber on Concrete">
      <point f="125.000" d="-0,362122"/>
      <point f="250.000" d="-1,191864"/>
      <point f="500.000" d="-3,665315"/>
      <point f="1000.000" d="-5,086383"/>
      <point f="2000.000" d="-5,376020"/>
      <point f="4000.000" d="-5,686362"/>
   </curve>
   <curve name="Absorption: Carpet Heavy, with Impermeable Latex Backing on 40oz Hairfelt or Foam Rubber on Concrete">
      <point f="250.000" d="-1,366771"/>
      <point f="500.000" d="-2,146702"/>
      <point f="1000.000" d="-1,804561"/>
      <point f="2000.000" d="-2,839967"/>
      <point f="4000.000" d="-4,317983"/>
   </curve>
   <curve name="Absorption: Concrete Block Light, Porous">
      <point f="125.000" d="-1,938200"/>
      <point f="250.000" d="-2,518120"/>
      <point f="500.000" d="-1,611509"/>
      <point f="1000.000" d="-1,487417"/>
      <point f="2000.000" d="-2,146702"/>
      <point f="4000.000" d="-1,249387"/>
   </curve>
   <curve name="Absorption: Concrete Block Dense, Painted">
      <point f="125.000" d="-0,457575"/>
      <point f="250.000" d="-0,222764"/>
      <point f="500.000" d="-0,268721"/>
      <point f="1000.000" d="-0,315171"/>
      <point f="2000.000" d="-0,409586"/>
      <point f="4000.000" d="-0,362122"/>
   </curve>
   <curve name="Absorption: Gypsum Board– 1/2″, Nailed to 2×4, 16″ O.C.">
      <point f="125.000" d="-1,487417"/>
      <point f="250.000" d="-0,457575"/>
      <point f="500.000" d="-0,222764"/>
      <point f="2000.000" d="-0,315171"/>
      <point f="4000.000" d="-0,409586"/>
   </curve>
   <curve name="Absorption: Marble or Glazed Tile">
      <point f="500.000" d="-0,043648"/>
      <point f="1000.000" d="-0,043648"/>
      <point f="4000.000" d="-0,087739"/>
   </curve>
   <curve name="Absorption: Plaster– Gypsum, or Lime, Smooth Finish on Tile or Brick">
      <point f="125.000" d="-0,056828"/>
      <point f="250.000" d="-0,065638"/>
      <point f="1000.000" d="-0,132283"/>
      <point f="2000.000" d="-0,177288"/>
      <point f="4000.000" d="-0,222764"/>
   </curve>
   <curve name="Absorption: Plaster– Gypsum, or Lime, Rough Finish on Lath">
      <point f="125.000" d="-0,655015"/>
      <point f="1000.000" d="-0,222764"/>
   </curve>
   <curve name="Absorption: Plaster– Gypsum, or Lime, Smooth Finish on Lath">
   </curve>
   <curve name="Absorption: Plywood Paneling– 3/8″ Thick">
      <point f="125.000" d="-1,426675"/>
      <point f="250.000" d="-1,079054"/>
      <point f="500.000" d="-0,809219"/>
      <point f="1000.000" d="-0,409586"/>
      <point f="2000.000" d="-0,457575"/>
      <point f="4000.000" d="-0,506100"/>
   </curve>
   <curve name="Absorption: Light Velour– 10oz/sq yd, Hung Straight, in Contact with Wall">
      <point f="250.000" d="-0,177288"/>
      <point f="500.000" d="-0,506100"/>
      <point f="1000.000" d="-0,809219"/>
      <point f="2000.000" d="-1,191864"/>
      <point f="4000.000" d="-1,870866"/>
   </curve>
   <curve name="Absorption: Medium Velour– 14oz/sq yd, draped to half area">
      <point f="125.000" d="-0,315171"/>
      <point f="250.000" d="-1,611509"/>
      <point f="500.000" d="-2,924298"/>
      <point f="1000.000" d="-6,020600"/>
      <point f="2000.000" d="-5,228787"/>
      <point f="4000.000" d="-3,979400"/>
   </curve>
   <curve name="Absorption: Heavy Velour– 18-oz/sq yd, Draped to Half Area">
      <point f="250.000" d="-1,870866"/>
      <point f="500.000" d="-3,467875"/>
      <point f="1000.000" d="-5,528420"/>
   </curve>
   <curve name="Absorption: Concrete or Terrazzo">
      <point f="500.000" d="-0,065638"/>
   </curve>
   <curve name="Absorption: Linoleum– Asphalt, Rubber, or Cork Tile on Concrete">
      <point f="2000.000" d="-0,132283"/>
   </curve>
   <curve name="Absorption: Wood">
      <point f="125.000" d="-0,705811"/>
      <point f="250.000" d="-0,506100"/>
      <point f="500.000" d="-0,457575"/>
      <point f="2000.000" d="-0,268721"/>
   </curve>
   <curve name="Absorption: Wood Parquet in Asphalt on Concrete">
      <point f="125.000" d="-0,177288"/>
      <point f="500.000" d="-0,315171"/>
      <point f="1000.000" d="-0,268721"/>
   </curve>
   <curve name="Absorption: Large Panes of Heavy Plate Glass">
      <point f="125.000" d="-0,861861"/>
      <point f="500.000" d="-0,177288"/>
   </curve>
   <curve name="Absorption: Ordinary Window Glass">
      <point f="125.000" d="-1,870866"/>
      <point f="250.000" d="-1,249387"/>
      <point f="500.000" d="-0,861861"/>
      <point f="1000.000" d="-0,555173"/>
      <point f="4000.000" d="-0,177288"/>
   </curve>
   <curve name="Absorption: Water Surface, e.g. Swimming Pool">
      <point f="125.000" d="-0,034883"/>
      <point f="250.000" d="-0,034883"/>
      <point f="500.000" d="-0,056828"/>
      <point f="1000.000" d="-0,705811"/>
   </curve>
   <curve name="Absorption: Chairs– Metal or Wood Seats, Each, Unoccupied">
      <point f="250.000" d="-0,915150"/>
      <point f="500.000" d="-1,079054"/>
      <point f="1000.000" d="-2,146702"/>
      <point f="2000.000" d="-2,076083"/>
      <point f="4000.000" d="-1,549020"/>
   </curve>
   <curve name="Absorption: Audience– Seated in Upholstered Seats, Per Square Foot of Floor Area">
      <point f="125.000" d="-3,979400"/>
      <point f="250.000" d="-5,850267"/>
      <point f="500.000" d="-9,208188"/>
      <point f="1000.000" d="-13,979400"/>
      <point f="2000.000" d="-11,549020"/>
      <point f="4000.000" d="-8,239087"/>
   </curve>
   <curve name="Absorption: Concrete (unpainted, rough finish)">
      <point f="250.000" d="-0,087739"/>
      <point f="2000.000" d="-0,362122"/>
      <point f="4000.000" d="-0,457575"/>
   </curve>
   <curve name="Absorption: Concrete (sealed or painted)">
   </curve>
   <curve name="Absorption: Marble or glazed tile">
   </curve>
   <curve name="Absorption: Vinyl tile or linoleum on concrete">
   </curve>
   <curve name="Absorption: Wood parquet on concrete">
   </curve>
   <curve name="Absorption: Wood flooring on joists">
   </curve>
   <curve name="Absorption: Benches (wooden, empty)">
      <point f="250.000" d="-0,409586"/>
      <point f="500.000" d="-0,362122"/>
      <point f="1000.000" d="-0,362122"/>
   </curve>
   <curve name="Absorption: Benches (wooden, 2/3 occupied)">
      <point f="125.000" d="-2,006595"/>
      <point f="250.000" d="-2,218487"/>
      <point f="500.000" d="-2,757241"/>
      <point f="1000.000" d="-3,279021"/>
      <point f="2000.000" d="-3,565473"/>
      <point f="4000.000" d="-3,279021"/>
   </curve>
   <curve name="Absorption: Benches (wooden, fully occupied)">
      <point f="125.000" d="-3,010300"/>
      <point f="250.000" d="-3,565473"/>
      <point f="500.000" d="-4,685211"/>
      <point f="1000.000" d="-6,197888"/>
      <point f="2000.000" d="-6,989700"/>
      <point f="4000.000" d="-6,197888"/>
   </curve>
   <curve name="Absorption: Benches (cushioned seats and backs, empty)">
      <point f="125.000" d="-1,674911"/>
      <point f="500.000" d="-2,365720"/>
      <point f="1000.000" d="-2,518120"/>
      <point f="2000.000" d="-2,441251"/>
      <point f="4000.000" d="-2,839967"/>
   </curve>
   <curve name="Absorption: Benches (cushioned seats and backs, 2/3 occupied)">
      <point f="125.000" d="-2,518120"/>
      <point f="500.000" d="-4,559320"/>
      <point f="2000.000" d="-5,528420"/>
      <point f="4000.000" d="-4,814861"/>
   </curve>
   <curve name="Absorption: Benches (cushioned seats and backs, fully occupied)">
      <point f="250.000" d="-4,436975"/>
      <point f="500.000" d="-6,197888"/>
      <point f="1000.000" d="-8,538720"/>
      <point f="2000.000" d="-8,538720"/>
   </curve>
   <curve name="Absorption: Theater seats (wood, empty)">
   </curve>
   <curve name="Absorption: Theater seats (wood, 2/3 occupied)">
      <point f="125.000" d="-1,804561"/>
      <point f="250.000" d="-1,023729"/>
      <point f="500.000" d="-1,426675"/>
   </curve>
   <curve name="Absorption: Theater seats (wood, fully occupied)">
      <point f="250.000" d="-1,549020"/>
      <point f="500.000" d="-2,218487"/>
   </curve>
   <curve name="Absorption: Seats (fabric-upholsterd, empty)">
      <point f="125.000" d="-2,924298"/>
      <point f="250.000" d="-4,685211"/>
      <point f="500.000" d="-6,989700"/>
      <point f="1000.000" d="-9,208188"/>
      <point f="2000.000" d="-7,447275"/>
      <point f="4000.000" d="-5,228787"/>
   </curve>
   <curve name="Absorption: Seats (fabric-upholsterd, fully occupied)">
   </curve>
   <curve name="Absorption: Brick (natural)">
   </curve>
   <curve name="Absorption: Brick (painted)">
   </curve>
   <curve name="Absorption: Concrete block (coarse)">
   </curve>
   <curve name="Absorption: Concrete block (painted)">
   </curve>
   <curve name="Absorption: Concrete (poured, rough finish, unpainted)">
   </curve>
   <curve name="Absorption: Doors (solid wood panels)">
      <point f="250.000" d="-0,315171"/>
   </curve>
   <curve name="Absorption: Glass (1/4 plate, large pane)">
   </curve>
   <curve name="Absorption: Glass (small pane)">
   </curve>
   <curve name="Absorption: Plasterboard (12mm (1/2) paneling on studs)">
   </curve>
   <curve name="Absorption: Plaster (gypsum or lime, on masonry)">
   </curve>
   <curve name="Absorption: Plaster (gypsum or lime, on wood lath)">
   </curve>
   <curve name="Absorption: Plywood (3mm(1/8) paneling over 31.7mm(1-1/4) airspace)">
      <point f="500.000" d="-0,555173"/>
   </curve>
   <curve name="Absorption: Plywood (3mm(1/8) paneling over 57.1mm( 2-1/4) airspace)">
      <point f="250.000" d="-0,969100"/>
      <point f="1000.000" d="-0,457575"/>
   </curve>
   <curve name="Absorption: Plywood (5mm(3/16) paneling over 50mm(2) airspace)">
      <point f="125.000" d="-2,076083"/>
   </curve>
   <curve name="Absorption: Plywood (5mm(3/16) panel, 25mm(1) fiberglass in 50mm(2) airspace)">
      <point f="125.000" d="-2,365720"/>
      <point f="250.000" d="-1,938200"/>
      <point f="500.000" d="-0,915150"/>
   </curve>
   <curve name="Absorption: Plywood (6mm(1/4) paneling, airspace, light bracing)">
      <point f="125.000" d="-1,549020"/>
      <point f="500.000" d="-0,705811"/>
   </curve>
   <curve name="Absorption: Plywood (10mm(3/8) paneling, airspace, light bracing)">
   </curve>
   <curve name="Absorption: Plywood (19mm(3/4) paneling, airspace, light bracing)">
      <point f="125.000" d="-0,969100"/>
      <point f="250.000" d="-0,861861"/>
   </curve>
   <curve name="Absorption: Drapery (10 oz/yd2, 340 g/m2, flat against wall)">
      <point f="1000.000" d="-0,861861"/>
      <point f="2000.000" d="-1,549020"/>
   </curve>
   <curve name="Absorption: Drapery (14 oz/yd2, 476 g/m2, flat against wall)">
      <point f="125.000" d="-0,222764"/>
      <point f="500.000" d="-0,604807"/>
      <point f="1000.000" d="-1,079054"/>
      <point f="2000.000" d="-1,674911"/>
   </curve>
   <curve name="Absorption: Drapery (18 oz/yd2, 612 g/m2, flat against wall)">
      <point f="250.000" d="-0,555173"/>
      <point f="500.000" d="-1,870866"/>
      <point f="1000.000" d="-2,839967"/>
      <point f="4000.000" d="-1,938200"/>
   </curve>
   <curve name="Absorption: Drapery (14 oz/yd2, 476 g/m2, pleated 50%)">
   </curve>
   <curve name="Absorption: Drapery (18 oz/yd2, 612 g/m2, pleated 50%)">
      <point f="500.000" d="-3,279021"/>
   </curve>
   <curve name="Absorption: Fiberglass board (25mm(1) thick)">
      <point f="125.000" d="-0,268721"/>
      <point f="1000.000" d="-10,000000"/>
      <point f="2000.000" d="-13,010300"/>
      <point f="4000.000" d="-16,989700"/>
   </curve>
   <curve name="Absorption: Fiberglass board (50mm(2) thick)">
      <point f="250.000" d="-6,197888"/>
      <point f="500.000" d="-20,000000"/>
      <point f="1000.000" d="-20,000000"/>
      <point f="2000.000" d="-20,000000"/>
      <point f="4000.000" d="-20,000000"/>
   </curve>
   <curve name="Absorption: Fiberglass board (75mm(3) thick)">
      <point f="125.000" d="-3,279021"/>
      <point f="250.000" d="-20,000000"/>
   </curve>
   <curve name="Absorption: Fiberglass board (100mm(4) thick)">
      <point f="125.000" d="-20,000000"/>
      <point f="4000.000" d="-15,228787"/>
   </curve>
   <curve name="Absorption: Open brick pattern over 75mm(3) fiberglass">
      <point f="125.000" d="-2,218487"/>
      <point f="250.000" d="-4,559320"/>
      <point f="500.000" d="-8,239087"/>
      <point f="2000.000" d="-4,559320"/>
   </curve>
   <curve name="Absorption: Pageboard over 25mm(1) fiberglass board">
      <point f="250.000" d="-1,674911"/>
      <point f="2000.000" d="-1,804561"/>
      <point f="4000.000" d="-0,555173"/>
   </curve>
   <curve name="Absorption: Pageboard over 50mm(2) fiberglass board">
      <point f="125.000" d="-1,307683"/>
      <point f="250.000" d="-15,228787"/>
      <point f="1000.000" d="-4,685211"/>
      <point f="4000.000" d="-0,655015"/>
   </curve>
   <curve name="Absorption: Pageboard over 75mm(3) fiberglass board">
      <point f="2000.000" d="-2,006595"/>
      <point f="4000.000" d="-0,705811"/>
   </curve>
   <curve name="Absorption: Performated metal (13% open, over 50mm(2) fiberglass)">
      <point f="125.000" d="-1,249387"/>
      <point f="1000.000" d="-15,228787"/>
      <point f="2000.000" d="-9,208188"/>
      <point f="4000.000" d="-10,969100"/>
   </curve>
   <curve name="Absorption: Plasterboard (12mm(1/2) in suspended ceiling grid)">
   </curve>
   <curve name="Absorption: Underlay in perforated metal panels (25mm(1) batts)">
      <point f="125.000" d="-3,098039"/>
      <point f="250.000" d="-6,575773"/>
      <point f="1000.000" d="-6,382722"/>
      <point f="2000.000" d="-10,000000"/>
      <point f="4000.000" d="-6,777807"/>
   </curve>
   <curve name="Absorption: Metal deck (perforated channels,25mm(1) batts)">
      <point f="125.000" d="-0,915150"/>
      <point f="250.000" d="-5,086383"/>
      <point f="2000.000" d="-3,187588"/>
      <point f="4000.000" d="-1,366771"/>
   </curve>
   <curve name="Absorption: Metal deck (perforated channels, 75mm(3) batts)">
      <point f="125.000" d="-5,686362"/>
      <point f="1000.000" d="-9,586073"/>
      <point f="4000.000" d="-1,611509"/>
   </curve>
   <curve name="Absorption: Plaster (gypsum or lime, on masonary)">
   </curve>
   <curve name="Absorption: Plaster (gypsum or lime, rough finish or timber lath)">
   </curve>
   <curve name="Absorption: Sprayed cellulose fiber (16mm(5/8) on solid backing)">
      <point f="250.000" d="-0,757207"/>
      <point f="500.000" d="-2,518120"/>
      <point f="1000.000" d="-6,777807"/>
      <point f="4000.000" d="-10,457575"/>
   </curve>
   <curve name="Absorption: Sprayed cellulose fiber (25mm(1) on solid backing)">
      <point f="250.000" d="-1,487417"/>
      <point f="500.000" d="-6,020600"/>
      <point f="1000.000" d="-16,989700"/>
   </curve>
   <curve name="Absorption: Sprayed cellulose fiber (32mm(1-1/4) on solid backing)">
      <point f="500.000" d="-5,686362"/>
      <point f="1000.000" d="-10,969100"/>
      <point f="2000.000" d="-16,989700"/>
   </curve>
   <curve name="Absorption: Sprayed cellulose fiber (75mm(3) on solid backing)">
      <point f="125.000" d="-5,228787"/>
      <point f="250.000" d="-13,010300"/>
      <point f="500.000" d="-60,000000"/>
      <point f="1000.000" d="-8,239087"/>
      <point f="2000.000" d="-8,239087"/>
      <point f="4000.000" d="-10,000000"/>
   </curve>
   <curve name="Absorption: Wood tongue-and-groove roof decking">
      <point f="125.000" d="-1,191864"/>
      <point f="2000.000" d="-0,604807"/>
   </curve>
   <curve name="Absorption: People-adults (per 1/10 person)">
      <point f="1000.000" d="-2,676062"/>
      <point f="2000.000" d="-3,010300"/>
      <point f="4000.000" d="-3,010300"/>
   </curve>
   <curve name="Absorption: People-high school students (per 1/10 person">
      <point f="125.000" d="-1,079054"/>
      <point f="500.000" d="-2,076083"/>
      <point f="1000.000" d="-2,365720"/>
      <point f="2000.000" d="-2,596373"/>
      <point f="4000.000" d="-2,596373"/>
   </curve>
   <curve name="Absorption: People-elementary students (per 1/10 person)">
      <point f="250.000" d="-1,135093"/>
      <point f="1000.000" d="-1,674911"/>
      <point f="2000.000" d="-1,870866"/>
   </curve>
   <curve name="Absorption: Ventilating grilles">
      <point f="500.000" d="-3,010300"/>
      <point f="1000.000" d="-3,010300"/>
      <point f="4000.000" d="-2,218487"/>
   </curve>
   <curve name="Absorption: Water or ice surface">
      <point f="1000.000" d="-0,065638"/>
      <point f="4000.000" d="-0,109954"/>
   </curve>
fellegis
Permanent link to this post Posted by fellegis » Sat Apr 09, 2016 8:36 pm
Sound absorption in special materials:
Code: Select all
   <curve name="Absorption: Embossed Foam 1/4in">
      <point f="500.000" d="-0,757207"/>
      <point f="1000.000" d="-1,191864"/>
      <point f="4000.000" d="-11,549020"/>
   </curve>
   <curve name="Absorption: Embossed Foam1/2in">
      <point f="250.000" d="-0,705811"/>
      <point f="500.000" d="-1,307683"/>
      <point f="1000.000" d="-3,767507"/>
   </curve>
   <curve name="Absorption: Embossed Foam 3/4in">
      <point f="250.000" d="-1,426675"/>
      <point f="500.000" d="-3,767507"/>
      <point f="2000.000" d="-12,218487"/>
   </curve>
   <curve name="Absorption: Embossed Foam 1in">
      <point f="4000.000" d="-7,958800"/>
   </curve>
   <curve name="Absorption: S000-030 hard foam with melamine">
      <point f="125.000" d="-0,159230"/>
      <point f="250.000" d="-0,414361"/>
      <point f="1000.000" d="-3,214816"/>
      <point f="2000.000" d="-9,172146"/>
      <point f="4000.000" d="-12,076083"/>
   </curve>
   <curve name="Absorption: S000-040 hard foam with melamine">
      <point f="250.000" d="-0,660068"/>
      <point f="500.000" d="-1,804561"/>
      <point f="1000.000" d="-5,767541"/>
      <point f="4000.000" d="-11,674911"/>
   </curve>
   <curve name="Absorption: S000-050 hard foam with melamine">
      <point f="125.000" d="-0,338583"/>
      <point f="250.000" d="-1,007268"/>
      <point f="500.000" d="-2,890369"/>
      <point f="1000.000" d="-8,761484"/>
      <point f="4000.000" d="-12,596373"/>
   </curve>
   <curve name="Absorption: S000-080 hard foam with melamine">
      <point f="125.000" d="-1,118205"/>
      <point f="250.000" d="-3,115802"/>
      <point f="500.000" d="-4,814861"/>
      <point f="1000.000" d="-15,850267"/>
      <point f="4000.000" d="-18,538720"/>
   </curve>
   <curve name="Absorption: S000-150 hard foam with melamine">
      <point f="125.000" d="-3,297541"/>
      <point f="250.000" d="-7,328283"/>
      <point f="500.000" d="-9,829667"/>
      <point f="1000.000" d="-13,767507"/>
      <point f="2000.000" d="-16,197888"/>
      <point f="4000.000" d="-22,218487"/>
   </curve>
   <curve name="Absorption: S070-020 hard foam with melamine">
      <point f="2000.000" d="-1,611509"/>
   </curve>
   <curve name="Absorption: S070-030 hard foam with melamine">
      <point f="500.000" d="-15,228787"/>
      <point f="2000.000" d="-3,467875"/>
   </curve>
      <point f="500.000" d="-16,989700"/>
      <point f="1000.000" d="-2,757241"/>
   </curve>
   <curve name="Absorption: S080-020 hard foam with melamine">
      <point f="250.000" d="-0,310503"/>
      <point f="500.000" d="-0,680339"/>
      <point f="1000.000" d="-2,232988"/>
      <point f="2000.000" d="-6,478175"/>
   </curve>
   <curve name="Absorption: S080-030 hard foam with melamine">
      <point f="125.000" d="-0,163737"/>
      <point f="250.000" d="-0,501223"/>
      <point f="500.000" d="-1,012748"/>
      <point f="1000.000" d="-4,190750"/>
      <point f="2000.000" d="-20,457575"/>
   </curve>
      <point f="125.000" d="-0,352691"/>
      <point f="250.000" d="-0,958256"/>
      <point f="500.000" d="-1,844223"/>
      <point f="1000.000" d="-8,477117"/>
      <point f="2000.000" d="-25,228787"/>
      <point f="4000.000" d="-10,315171"/>
   </curve>
   <curve name="Absorption: S200-020 open cell PU foam">
      <point f="125.000" d="-0,181814"/>
      <point f="250.000" d="-0,291884"/>
      <point f="500.000" d="-0,467237"/>
      <point f="1000.000" d="-0,979971"/>
      <point f="2000.000" d="-2,790143"/>
      <point f="4000.000" d="-5,559552"/>
   </curve>
   <curve name="Absorption: S200-030 open cell PU foam">
      <point f="500.000" d="-1,366771"/>
      <point f="2000.000" d="-5,086383"/>
   </curve>
   <curve name="Absorption: S200-040 open cell PU foam">
      <point f="125.000" d="-0,381045"/>
      <point f="250.000" d="-0,974532"/>
      <point f="500.000" d="-3,297541"/>
      <point f="1000.000" d="-18,538720"/>
      <point f="2000.000" d="-5,934598"/>
      <point f="4000.000" d="-9,030900"/>
   </curve>
   <curve name="Absorption: S200-050 open cell PU foam">
      <point f="125.000" d="-0,409586"/>
      <point f="250.000" d="-0,803990"/>
      <point f="500.000" d="-2,048154"/>
      <point f="1000.000" d="-7,520267"/>
      <point f="2000.000" d="-5,900669"/>
      <point f="4000.000" d="-13,187588"/>
   </curve>
   <curve name="Absorption: S200-080 open cell PU foam">
      <point f="125.000" d="-2,111249"/>
      <point f="250.000" d="-3,882767"/>
      <point f="500.000" d="-6,401645"/>
      <point f="1000.000" d="-4,962093"/>
      <point f="2000.000" d="-7,328283"/>
      <point f="4000.000" d="-7,695511"/>
   </curve>
   <curve name="Absorption: S220-070 open cell PU foam">
      <point f="125.000" d="-0,006084"/>
      <point f="250.000" d="-0,017407"/>
      <point f="500.000" d="-0,032695"/>
      <point f="1000.000" d="-0,042771"/>
      <point f="2000.000" d="-0,042771"/>
      <point f="4000.000" d="-0,044526"/>
   </curve>
   <curve name="Absorption: S220-100 open cell PU foam">
      <point f="125.000" d="-0,007824"/>
      <point f="250.000" d="-0,026573"/>
      <point f="500.000" d="-0,046281"/>
      <point f="1000.000" d="-0,046281"/>
      <point f="2000.000" d="-0,044087"/>
      <point f="4000.000" d="-0,048037"/>
   </curve>
   <curve name="Absorption: S230-030 open cell PU foam">
      <point f="1000.000" d="-1,023729"/>
   </curve>
   <curve name="Absorption: S230-040 open cell PU foam">
      <point f="2000.000" d="-7,212464"/>
   </curve>
   <curve name="Absorption: S230-060 open cell PU foam">
      <point f="500.000" d="-8,860566"/>
      <point f="1000.000" d="-6,575773"/>
   </curve>
   <curve name="Absorption: S250-020 open cell PU foam">
      <point f="125.000" d="-0,204516"/>
      <point f="250.000" d="-0,282604"/>
      <point f="500.000" d="-1,045775"/>
      <point f="1000.000" d="-7,328283"/>
      <point f="2000.000" d="-6,090649"/>
      <point f="4000.000" d="-3,187588"/>
   </curve>
   <curve name="Absorption: S250-030 open cell PU foam">
      <point f="125.000" d="-0,195421"/>
      <point f="250.000" d="-0,741724"/>
      <point f="500.000" d="-2,992963"/>
      <point f="2000.000" d="-5,654311"/>
      <point f="4000.000" d="-7,746907"/>
   </curve>
   <curve name="Absorption: S255-010 open cell PU foam">
      <point f="1000.000" d="-1,426675"/>
      <point f="2000.000" d="-3,872161"/>
      <point f="4000.000" d="-4,202164"/>
   </curve>
   <curve name="Absorption: S255-020 open cell PU foam">
      <point f="125.000" d="-0,136762"/>
      <point f="500.000" d="-1,266794"/>
      <point f="1000.000" d="-4,989407"/>
      <point f="2000.000" d="-12,757241"/>
      <point f="4000.000" d="-4,571746"/>
   </curve>
   <curve name="Absorption: S255-030 open cell PU foam">
      <point f="125.000" d="-0,604807"/>
   </curve>
   <curve name="Absorption: S260-015 open cell PU foam">
      <point f="125.000" d="-0,039263"/>
      <point f="500.000" d="-0,515870"/>
      <point f="1000.000" d="-1,965429"/>
      <point f="2000.000" d="-15,686362"/>
      <point f="4000.000" d="-6,420652"/>
   </curve>
   <curve name="Absorption: S260-020 open cell PU foam">
      <point f="250.000" d="-0,319843"/>
      <point f="500.000" d="-0,788339"/>
      <point f="1000.000" d="-2,660007"/>
      <point f="2000.000" d="-13,767507"/>
      <point f="4000.000" d="-5,436340"/>
   </curve>
   <curve name="Absorption: S260-030 open cell PU foam">
      <point f="125.000" d="-0,282604"/>
      <point f="250.000" d="-0,644927"/>
      <point f="500.000" d="-3,362991"/>
      <point f="1000.000" d="-9,871628"/>
      <point f="2000.000" d="-6,289321"/>
      <point f="4000.000" d="-5,128616"/>
   </curve>
   <curve name="Absorption: S260-050 open cell PU foam">
      <point f="125.000" d="-0,695604"/>
      <point f="250.000" d="-1,307683"/>
      <point f="500.000" d="-7,144427"/>
      <point f="1000.000" d="-10,457575"/>
      <point f="2000.000" d="-5,686362"/>
      <point f="4000.000" d="-8,696662"/>
   </curve>
   <curve name="Absorption: S280-020 open cell PU foam">
      <point f="125.000" d="-0,241089"/>
      <point f="250.000" d="-0,462403"/>
      <point f="500.000" d="-2,204035"/>
      <point f="1000.000" d="-7,471470"/>
      <point f="4000.000" d="-3,325470"/>
   </curve>
   <curve name="Absorption: S280-030 open cell PU foam">
      <point f="250.000" d="-0,550241"/>
      <point f="500.000" d="-1,985963"/>
      <point f="1000.000" d="-8,664611"/>
      <point f="2000.000" d="-6,234230"/>
      <point f="4000.000" d="-8,477117"/>
   </curve>
   <curve name="Absorption: S280-040 open cell PU foam">
      <point f="125.000" d="-0,535477"/>
      <point f="250.000" d="-1,348960"/>
      <point f="500.000" d="-7,670039"/>
      <point f="1000.000" d="-4,634416"/>
      <point f="2000.000" d="-4,329736"/>
      <point f="4000.000" d="-3,968556"/>
   </curve>
   <curve name="Absorption: S580-020 open cell PU foam">
      <point f="125.000" d="-0,168249"/>
      <point f="250.000" d="-0,329203"/>
      <point f="500.000" d="-0,565055"/>
      <point f="1000.000" d="-1,278437"/>
      <point f="2000.000" d="-3,655227"/>
      <point f="4000.000" d="-6,458916"/>
   </curve>
   <curve name="Absorption: S580-030 open cell PU foam">
      <point f="125.000" d="-0,433514"/>
      <point f="250.000" d="-0,899095"/>
      <point f="500.000" d="-4,236586"/>
      <point f="1000.000" d="-7,721133"/>
      <point f="2000.000" d="-4,400934"/>
      <point f="4000.000" d="-4,546929"/>
   </curve>
   <curve name="Absorption: S580-040 open cell PU foam">
      <point f="125.000" d="-0,506100"/>
      <point f="250.000" d="-1,266794"/>
      <point f="500.000" d="-7,520267"/>
      <point f="1000.000" d="-5,900669"/>
      <point f="2000.000" d="-3,882767"/>
      <point f="4000.000" d="-4,436975"/>
   </curve>
   <curve name="Absorption: S450-005 SK rebounded PU foam with 120 kg/m3 bulk density">
      <point f="125.000" d="-1,366771"/>
      <point f="500.000" d="-1,739252"/>
      <point f="4000.000" d="-3,098039"/>
   </curve>
   <curve name="Absorption: S450-010 SK rebounded PU foam with 120 kg/m3 bulk density">
      <point f="1000.000" d="-2,441251"/>
      <point f="2000.000" d="-2,676062"/>
   </curve>
   <curve name="Absorption: S450-020 SK rebounded PU foam with 120 kg/m3 bulk density">
      <point f="2000.000" d="-2,924298"/>
      <point f="4000.000" d="-3,665315"/>
   </curve>
   <curve name="Absorption: S471-020 rebounded PU foam">
      <point f="500.000" d="-5,086383"/>
   </curve>
   <curve name="Absorption: S471-030 rebounded PU foam">
      <point f="500.000" d="-5,376020"/>
      <point f="2000.000" d="-2,757241"/>
   </curve>
   <curve name="Absorption: S471-040 rebounded PU foam">
      <point f="250.000" d="-3,010300"/>
      <point f="1000.000" d="-2,596373"/>
      <point f="4000.000" d="-1,674911"/>
   </curve>
   <curve name="Absorption: S480-020 rebounded PU foam">
      <point f="500.000" d="-0,925886"/>
      <point f="1000.000" d="-2,856702"/>
      <point f="2000.000" d="-11,487417"/>
      <point f="4000.000" d="-10,604807"/>
   </curve>
   <curve name="Absorption: S480-030 rebounded PU foam">
      <point f="125.000" d="-0,264104"/>
      <point f="500.000" d="-1,586405"/>
      <point f="1000.000" d="-5,654311"/>
      <point f="2000.000" d="-23,979400"/>
   </curve>
   <curve name="Absorption: S480-040 rebounded PU foam">
      <point f="250.000" d="-0,942041"/>
      <point f="500.000" d="-2,975695"/>
      <point f="1000.000" d="-10,861861"/>
      <point f="2000.000" d="-12,006595"/>
      <point f="4000.000" d="-14,089354"/>
   </curve>
   <curve name="Absorption: S490-020 rebounded PU foam">
      <point f="125.000" d="-0,141246"/>
      <point f="250.000" d="-0,352691"/>
      <point f="500.000" d="-0,909791"/>
      <point f="1000.000" d="-2,525882"/>
      <point f="2000.000" d="-8,894103"/>
      <point f="4000.000" d="-12,441251"/>
   </curve>
   <curve name="Absorption: S490-030 rebounded PU foam">
      <point f="250.000" d="-0,525663"/>
      <point f="500.000" d="-1,511953"/>
      <point f="1000.000" d="-4,723701"/>
      <point f="4000.000" d="-7,544873"/>
   </curve>
   <curve name="Absorption: S490-040 rebounded PU foam">
      <point f="125.000" d="-0,366845"/>
      <point f="250.000" d="-1,018235"/>
      <point f="500.000" d="-3,655227"/>
      <point f="1000.000" d="-12,839967"/>
      <point f="2000.000" d="-8,761484"/>
   </curve>
   <curve name="Absorption: S360-022 SK open cell PU foam + bituminous felt">
      <point f="125.000" d="-0,154727"/>
      <point f="250.000" d="-0,366845"/>
      <point f="500.000" d="-0,893756"/>
      <point f="1000.000" d="-3,071531"/>
      <point f="2000.000" d="-13,098039"/>
      <point f="4000.000" d="-7,423214"/>
   </curve>
   <curve name="Absorption: S360-032 SK open cell PU foam + bituminous felt">
      <point f="125.000" d="-0,333890"/>
      <point f="250.000" d="-0,840728"/>
      <point f="500.000" d="-2,644011"/>
      <point f="2000.000" d="-8,041003"/>
      <point f="4000.000" d="-5,800443"/>
   </curve>
   <curve name="Absorption: S369-031 SK open cell PU foam + EPDM rumbling inhibitor + rebounded foam">
      <point f="500.000" d="-2,175274"/>
      <point f="1000.000" d="-5,482136"/>
      <point f="2000.000" d="-5,816987"/>
      <point f="4000.000" d="-8,664611"/>
   </curve>
   <curve name="Absorption: S380-022 SK open cell PU foam + bitumen">
      <point f="125.000" d="-0,127808"/>
      <point f="500.000" d="-0,731433"/>
      <point f="1000.000" d="-2,321024"/>
      <point f="4000.000" d="-5,622494"/>
   </curve>
   <curve name="Absorption: S380-032 SK open cell PU foam + bitumen">
      <point f="125.000" d="-0,301184"/>
      <point f="250.000" d="-0,990869"/>
      <point f="500.000" d="-3,496925"/>
      <point f="1000.000" d="-8,356471"/>
      <point f="4000.000" d="-5,243288"/>
   </curve>
   <curve name="Absorption: S389-031 SK open cell PU foam + EPDM rumbling inhibitor + rebounded foam">
      <point f="125.000" d="-0,287242"/>
      <point f="250.000" d="-0,589858"/>
      <point f="500.000" d="-2,350770"/>
      <point f="1000.000" d="-4,894550"/>
      <point f="2000.000" d="-8,013429"/>
      <point f="4000.000" d="-6,270880"/>
   </curve>
   <curve name="Absorption: S293-005 open cell PU foam">
      <point f="2000.000" d="-0,705811"/>
      <point f="4000.000" d="-2,924298"/>
   </curve>
   <curve name="Absorption: S430-003 SK stitched glass wool">
      <point f="125.000" d="-0,017407"/>
      <point f="250.000" d="-0,101054"/>
      <point f="500.000" d="-0,245682"/>
      <point f="2000.000" d="-2,196827"/>
      <point f="4000.000" d="-7,121983"/>
   </curve>
   <curve name="Absorption: S430-007 SK stitched glass wool">
      <point f="125.000" d="-0,092173"/>
      <point f="250.000" d="-0,145735"/>
      <point f="500.000" d="-0,409586"/>
      <point f="2000.000" d="-4,485500"/>
      <point f="4000.000" d="-6,363880"/>
   </curve>
   <curve name="Absorption: S430-012 SK stitched glass wool">
      <point f="250.000" d="-0,423927"/>
      <point f="500.000" d="-1,090204"/>
      <point f="1000.000" d="-2,247537"/>
      <point f="2000.000" d="-3,788237"/>
      <point f="4000.000" d="-4,111683"/>
   </curve>
   <curve name="Absorption: S801-010 open cell PU foam">
      <point f="125.000" d="-0,083310"/>
      <point f="250.000" d="-0,287242"/>
      <point f="500.000" d="-0,985417"/>
      <point f="1000.000" d="-4,609239"/>
      <point f="2000.000" d="-1,567672"/>
      <point f="4000.000" d="-0,757207"/>
   </curve>
   <curve name="Absorption: Polyester 0.5in">
      <point f="125.000" d="0,000000"/>
      <point f="250.000" d="-0,362122"/>
      <point f="1000.000" d="-3,467875"/>
      <point f="4000.000" d="-13,010300"/>
   </curve>
   <curve name="Absorption: Poliesther 0.75in">
      <point f="4000.000" d="-8,538720"/>
   </curve>
   <curve name="Absorption: Polyester 1in">
      <point f="500.000" d="-5,850267"/>
      <point f="1000.000" d="-15.000"/>
   </curve>
   <curve name="Absorption: Polyester 1.5in">
      <point f="500.000" d="-6,382722"/>
      <point f="4000.000" d="-15.000"/>
   </curve>
   <curve name="Absorption: Polyether 1/2in">
      <point f="1000.000" d="-3,665315"/>
      <point f="4000.000" d="-8,860566"/>
   </curve>
   <curve name="Absorption: Polyether 3/4in">
      <point f="500.000" d="-2,441251"/>
   </curve>
   <curve name="Absorption: Polyether 1in">
      <point f="1000.000" d="-8,860566"/>
   </curve>
   <curve name="Absorption: Polyether 1-1/2in">
      <point f="250.000" d="-4,948500"/>
      <point f="500.000" d="-9,586073"/>
      <point f="2000.000" d="-4,948500"/>
      <point f="4000.000" d="-6,382722"/>
   </curve>
   <curve name="Absorption: Metalized mylar foam 1/2in">
      <point f="4000.000" d="-1,426675"/>
   </curve>
   <curve name="Absorption: Metalized mylar foam 3/4in">
      <point f="250.000" d="-1,739252"/>
      <point f="1000.000" d="-2,076083"/>
      <point f="2000.000" d="-1,487417"/>
   </curve>
   <curve name="Absorption: Metalized mylar foam 1in">
      <point f="500.000" d="-4,089354"/>
      <point f="1000.000" d="-1,611509"/>
      <point f="4000.000" d="-2,676062"/>
   </curve>
   <curve name="Absorption: Metalized mylar foam 1.5in">
   </curve>
   <curve name="Absorption: Vinyl foam 1/2in">
      <point f="500.000" d="-3,187588"/>
      <point f="4000.000" d="-4,948500"/>
   </curve>
   <curve name="Absorption: Vinyl foam 1in">
      <point f="250.000" d="-2,006595"/>
      <point f="500.000" d="-10,000000"/>
   </curve>
   <curve name="Absorption: FOAM MELAMINE 1/2in">
      <point f="250.000" d="-0,604807"/>
      <point f="4000.000" d="-7,212464"/>
   </curve>
   <curve name="Absorption: FOAM MELAMINE 3/4in">
      <point f="1000.000" d="-4,559320"/>
   </curve>
   <curve name="Absorption: FOAM MELAMINE 1in">
      <point f="1000.000" d="-7,447275"/>
   </curve>
   <curve name="Absorption: FOAM MELAMINE 1-1/2in">
   </curve>
   <curve name="Absorption: FOAM MELAMINE 1in Reinforced Facing">
      <point f="250.000" d="-2,146702"/>
      <point f="1000.000" d="-3,098039"/>
      <point f="2000.000" d="-1,366771"/>
      <point f="4000.000" d="-2,441251"/>
   </curve>
   <curve name="Absorption: S400-003 PU-rubber heavy compound material">
      <point f="125.000" d="-27,000000"/>
      <point f="250.000" d="-28,000000"/>
      <point f="500.000" d="-33,000000"/>
      <point f="1000.000" d="-41,000000"/>
      <point f="2000.000" d="-43,000000"/>
      <point f="4000.000" d="-49,000000"/>
   </curve>
   <curve name="Absorption: S400-006 PU-rubber heavy compound material">
      <point f="125.000" d="-28,000000"/>
      <point f="500.000" d="-35,000000"/>
      <point f="1000.000" d="-40,000000"/>
      <point f="2000.000" d="-49,000000"/>
      <point f="4000.000" d="-63,000000"/>
   </curve>
   <curve name="Absorption: S400-010 PU-rubber heavy compound material">
      <point f="125.000" d="-29,000000"/>
      <point f="500.000" d="-36,000000"/>
      <point f="1000.000" d="-44,000000"/>
      <point f="2000.000" d="-56,000000"/>
      <point f="4000.000" d="-74,000000"/>
   </curve>
   <curve name="Absorption: S409-003 SK EPDM">
      <point f="250.000" d="-30,000000"/>
      <point f="500.000" d="-40,000000"/>
      <point f="1000.000" d="-47,000000"/>
      <point f="2000.000" d="-46,000000"/>
      <point f="4000.000" d="-45,000000"/>
   </curve>
fellegis
Permanent link to this post Posted by fellegis » Mon Apr 11, 2016 9:51 am
Sennheiser microphones frequency responses:
Code: Select all
<curve name="Sennheiser e604">
   <point f="20.0000" d="-40.000"/>
   <point f="40.0000" d="-11.000"/>
   <point f="50.0000" d="-10.000"/>
   <point f="110.0000" d="-1.500"/>
   <point f="500.0000" d="-1.000"/>
   <point f="550.0000" d="0.000"/>
   <point f="1000.0000" d="0.000"/>
   <point f="4000.0000" d="4.000"/>
   <point f="5000.0000" d="4.000"/>
   <point f="8000.0000" d="0.500"/>
   <point f="15000.0000" d="0.000"/>
   <point f="20000.0000" d="-10.00"/>
</curve>
<curve name="Sennheiser e835">
   <point f="20.0000" d="-120.000"/>
   <point f="40.0000" d="-10.000"/>
   <point f="100.0000" d="-4.000"/>
   <point f="150.0000" d="-3.000"/>
   <point f="2500.0000" d="-2.000"/>
   <point f="7000.0000" d="2.000"/>
   <point f="11000.0000" d="1.500"/>
   <point f="20000.0000" d="-20.00"/>
</curve>
<curve name="Sennheiser e838">
   <point f="40.0000" d="-24.000"/>
   <point f="150.0000" d="-8.000"/>
   <point f="200.0000" d="-7.000"/>
   <point f="500.0000" d="-7.000"/>
   <point f="2000.0000" d="-4.000"/>
   <point f="6000.0000" d="-2.000"/>
   <point f="8000.0000" d="-4.500"/>
   <point f="9000.0000" d="-4.500"/>
   <point f="10000.0000" d="-2.000"/>
   <point f="12000.0000" d="-0.500"/>
   <point f="20000.0000" d="-36.00"/>
</curve>
<curve name="Sennheiser e902">
   <point f="40.0000" d="-15.000"/>
   <point f="60.0000" d="-10.000"/>
   <point f="700.0000" d="-25.000"/>
   <point f="4000.0000" d="-4.000"/>
   <point f="5000.0000" d="-3.000"/>
   <point f="6000.0000" d="-4.000"/>
   <point f="7000.0000" d="-4.000"/>
   <point f="10000.0000" d="-2.500"/>
   <point f="20000.0000" d="-40.000"/>
</curve>
<curve name="Sennheiser e904">
   <point f="125.0000" d="-6.000"/>
   <point f="4000.0000" d="-2.000"/>
   <point f="8000.0000" d="-1.5000"/>
   <point f="9000.0000" d="-2.000"/>
   <point f="12000.0000" d="0.00"/>
   <point f="12500.0000" d="0.000"/>
   <point f="20000.0000" d="-35.000"/>
</curve>
<curve name="Sennheiser e905">
   <point f="40.0000" d="-18.000"/>
   <point f="200.0000" d="-6.000"/>
   <point f="2500.0000" d="0.000"/>
   <point f="5500.0000" d="4.000"/>
   <point f="10000.0000" d="1.5000"/>
   <point f="12000.0000" d="2.000"/>
</curve>
<curve name="Sennheiser e906 (1)">
   <point f="20.0000" d="-80.000"/>
   <point f="170.0000" d="-6.000"/>
   <point f="410.0000" d="-3.000"/>
   <point f="1024.0000" d="-3.000"/>
   <point f="3000.0000" d="0.000"/>
   <point f="4500.0000" d="4.000"/>
   <point f="7000.0000" d="-2.000"/>
   <point f="12000.0000" d="-4.000"/>
   <point f="15000.0000" d="-10.000"/>
   <point f="15000.0000" d="-25.000"/>
</curve>
<curve name="Sennheiser e906 (2)">
   <point f="4000.0000" d="2.000"/>
</curve>
<curve name="Sennheiser e906 (3)">
   <point f="4000.0000" d="1.000"/>
</curve>
<curve name="Sennheiser e935">
   <point f="40.0000" d="-20.000"/>
   <point f="150.0000" d="-4.000"/>
   <point f="200.0000" d="-3.000"/>
   <point f="400.0000" d="-3.000"/>
   <point f="1000.0000" d="-0.500"/>
   <point f="2000.0000" d="-0.500"/>
   <point f="5000.0000" d="2.500"/>
   <point f="10000.0000" d="2.500"/>
   <point f="20000.0000" d="-25.00"/>
</curve>
<curve name="Sennheiser e945">
   <point f="40.0000" d="-22.000"/>
   <point f="150.0000" d="-6.000"/>
   <point f="200.0000" d="-5.000"/>
   <point f="500.0000" d="-5.000"/>
   <point f="2000.0000" d="-2.000"/>
   <point f="6000.0000" d="0.000"/>
   <point f="8000.0000" d="-2.500"/>
   <point f="9000.0000" d="-2.500"/>
   <point f="10000.0000" d="0.000"/>
</curve>
fellegis
Permanent link to this post Posted by fellegis » Mon Apr 11, 2016 9:56 am
Some microphones frequency data:
Code: Select all
<curve name="Shure SM-58">
   <point f="99.9000" d="-90.000"/>
   <point f="128.0000" d="0.000"/>
   <point f="1500.0000" d="0.000"/>
   <point f="3500.0000" d="4.000"/>
   <point f="6000.0000" d="5.000"/>
   <point f="7500.0000" d="0.000"/>
   <point f="8500.0000" d="3.000"/>
   <point f="10000.0000" d="4.000"/>
   <point f="15000.0000" d="-7.500"/>
   <point f="20000.0000" d="-20.000"/>
</curve>
<curve name="EM-400">
   <point f="49.9000" d="-90.000"/>
   <point f="50.0000" d="0.000"/>
   <point f="13000.0000" d="0.000"/>
   <point f="13001.0000" d="-90.000"/>
</curve>
<curve name="EM-600">
   <point f="29.9000" d="-90.000"/>
   <point f="30.0000" d="0.000"/>
   <point f="19999.0000" d="0.000"/>
   <point f="20000.0000" d="-90.000"/>
</curve>
<curve name="EM-700">
   <point f="34.9000" d="-90.000"/>
   <point f="35.0000" d="0.000"/>
</curve>
<curve name="EM-800">
   <point f="59.9000" d="-90.000"/>
   <point f="60.0000" d="0.000"/>
</curve>
<curve name="DM-1100">
   <point f="100.0000" d="0.000"/>
   <point f="12000.0000" d="0.000"/>
   <point f="12001.0000" d="-90.000"/>
</curve>
<curve name="DM-1200">
</curve>
<curve name="DM-1300">
   <point f="69.9000" d="-90.000"/>
   <point f="70.0000" d="0.000"/>
   <point f="15001.0000" d="-90.000"/>
</curve>
<curve name="PM-222">
   <point f="10001.0000" d="-90.000"/>
</curve>
<curve name="PM-120">
</curve>
<curve name="PM-660">
</curve>
<curve name="WT-58xx">
   <point f="99.9000" d="-110.000"/>
   <point f="15001.0000" d="-110.000"/>
</curve>
<curve name="WT-4820">
   <point f="49.9000" d="-102.000"/>
   <point f="18000.0000" d="0.000"/>
   <point f="18001.0000" d="-102.000"/>
</curve>
<curve name="WTU-4800">
</curve>
<curve name="WT-2100 (Portable)">
   <point f="199.9000" d="-90.000"/>
   <point f="200.0000" d="0.000"/>
   <point f="5000.0000" d="0.000"/>
   <point f="5001.0000" d="-90.000"/>
</curve>
<curve name="WT-2100 (Desktop)">
   <point f="149.9000" d="-90.000"/>
   <point f="150.0000" d="0.000"/>
   <point f="6001.0000" d="-90.000"/>
</curve>
<curve name="IR-200M">
</curve>
<curve name="IR-702T">
</curve>
<curve name="PM-20EV US">
</curve>
<curve name="M936">
   <point f="14999.0000" d="0.000"/>
   <point f="15000.0000" d="-90.000"/>
</curve>
<curve name="M976">
   <point f="17999.0000" d="0.000"/>
   <point f="18000.0000" d="-90.000"/>
</curve>
<curve name="MC260">
</curve>
<curve name="MC101">
   <point f="11999.0000" d="0.000"/>
   <point f="12000.0000" d="-90.000"/>
</curve>
fellegis
Permanent link to this post Posted by fellegis » Mon Apr 11, 2016 1:25 pm
3 way speakers frequency curves:
Code: Select all
   <curve name="3way - Low">
      <point f="20.000" d="-3.000"/>
      <point f="40.000" d="0.000"/>
      <point f="50.000" d="0.000"/>
      <point f="100.000" d="-6.000"/>
      <point f="200.000" d="-24.000"/>
      <point f="300.000" d="-36.000"/>
      <point f="20000.000" d="-120.000"/>
   </curve>
   <curve name="3way - Middle">
      <point f="20.000" d="-42.000"/>
      <point f="200.000" d="-1.000"/>
      <point f="300.000" d="-0.500"/>
      <point f="400.000" d="0.000"/>
      <point f="600.000" d="0.000"/>
      <point f="1000.000" d="-0.500"/>
      <point f="2000.000" d="-6.000"/>
      <point f="3500.000" d="-18.000"/>
      <point f="6500.000" d="-42.000"/>
   </curve>
   <curve name="3way - High">
      <point f="20.000" d="-120.000"/>
      <point f="600.000" d="-42.000"/>
      <point f="1000.000" d="-24.000"/>
      <point f="3500.000" d="-1.000"/>
      <point f="5000.000" d="0.000"/>
      <point f="12000.000" d="0.000"/>
      <point f="20000.000" d="-3.000"/>
   </curve>
fellegis
Permanent link to this post Posted by yugioh47 » Sun Aug 28, 2016 10:01 pm
can you please put a range text window into this generator?
yugioh47
Permanent link to this post Posted by agkdflç » Mon Nov 07, 2016 5:05 pm
anyone got a ITU-R 468 weighted curve?
agkdflç
Permanent link to this post Posted by steve » Tue Nov 08, 2016 10:30 am
agkdflç wrote:anyone got a ITU-R 468 weighted curve?
I've not seen one posted, but you can get the figures to create one yourself from here: https://en.wikipedia.org/wiki/ITU-R_468 ... urement.29
If you need help converting those figures into a EQ Curve file, please ask. If you manage to do it yourself, please feel free to post your file to this forum topic.
Permanent link to this post Posted by agkdflç » Tue Nov 08, 2016 2:50 pm
welllll,
that made me learn some new things about LibreOffice Calc :-)
If someone needs another "version" I can do it very quick now in my sheet
here it is normalized and inverted:
Code: Select all
   <curve name="ITU-R 468 noise weighting">
<point f="31.5" d="0" />
<point f="63" d="-6" />
<point f="100" d="-10.1" />
<point f="200" d="-16.1" />
<point f="400" d="-22.1" />
<point f="800" d="-28" />
<point f="1000" d="-29.9" />
<point f="2000" d="-35.5" />
<point f="3150" d="-38.9" />
<point f="4000" d="-40.4" />
<point f="5000" d="-41.6" />
<point f="6300" d="-42.1" />
<point f="7100" d="-41.9" />
<point f="8000" d="-41.3" />
<point f="9000" d="-40" />
<point f="10000" d="-38" />
<point f="12500" d="-29.9" />
<point f="14000" d="-24.6" />
<point f="16000" d="-18.2" />
<point f="20000" d="-7.7" />
   </curve>
agkdflç
PreviousNext
Return to Audio Processing
Who is online
Users browsing this forum: Bing [Bot] and 4 guests
