Submit your EQ Curves
Re: Submit your EQ Curves
Permanent link to this post Posted by Gale Andrews » Thu Jun 11, 2015 12:50 pm
elesser wrote:Here's a EQ curve I made for removing Pre-Emphasis that was used on some older CDs. The values for this curve were sourced from here: http://audioxpress.com/files/galo3025.pdf
This allows for easy de-emphasis of CDs in relatively high ("ideal") resolution.
There is some more about CD pre-emphasis here: http://wiki.hydrogenaud.io/index.php?title=Pre-emphasis.
However since some CD rippers these days detect pre-emphasised CD's and apply a de-emphasis filter, you would need to know what ripper processed the files before deciding to use the filter.
Permanent link to this post Posted by fellegis » Sun Oct 11, 2015 9:46 pm
Sorry, i bad english.
I experiment with longer EQ curves:
http://pvtv.hu/tarolo/out_files/EQgen.tar.xz
fellegis
Operating System: GNU/Linux other
effects> Equalizer
Permanent link to this post Posted by zap_zap_1 » Sat Oct 24, 2015 8:21 pm
ultima.XML
(21.38 KiB) Downloaded 151 times
Use audacity as equalizer.
At home and in the car.
Place a curve in the case of utilities' other forum friends who may like me
use audacity to equalize the tracks.
Great program.
Thanks to the team of Audacity.
zap_zap_1
Re: effects> Equalizer
Permanent link to this post Posted by Gale Andrews » Sat Oct 24, 2015 8:32 pm
zap_zap_1 wrote:
ultima.XML
Great program.
Thank you, I moved your post to this topic where we store user's suggested EQ curves.
How would you describe the purpose and special qualities of your curve?
Permanent link to this post Posted by zap_zap_1 » Wed Nov 04, 2015 7:05 pm
Audacity curve EQ.XML
(20.05 KiB) Downloaded 138 times
Gale Andrews wrote:I haven't got time to produce possible Audacity curves myself but maybe as a starting point for someone to customise:
First, the sony-oxford R3 EQs from this page:
http://www.sonnoxplugins.com/pub/plugin ... le2-eq.htm
Second, http://sjeng.org/ftp/fb2k/eq_presets.zip
Those are .feq presets for Foobar 2000, but they are plain text files with 18 gain values for the following frequencies in Hz:
55, 77, 110, 156, 220, 311, 440, 622, 880, 1200, 1800, 2500, 3500, 5000, 7000, 10000, 14000, 20000
The 20 presets in the zip are:
1965
Air
Brittle
Car Stereo
Classic V
Clear
Dark
DEATH
Drums
Flat
Home Theater
Loudness
Metal
Pop
Premaster
Presence
Punch & Sparkle
Shimmer
Soft Bass
Strings
More explanation of how to use the above data is at viewtopic.php?p=203701#p203701 .
zap_zap_1
Permanent link to this post Posted by Gale Andrews » Wed Nov 04, 2015 7:16 pm
Thanks but there is not much point posting a curve with a generic name and no other indication what it should be used for.
Is it supposed to be a curve for a specific genre of music?
Permanent link to this post Posted by fellegis » Wed Mar 30, 2016 11:04 am
EQOctaves.xml :
Code: Select all
<equalizationeffect>
<curve name="Octave 0">
   <point f="20.9000" d="-3.000"/>
   <point f="21.0000" d="3.000"/>
   <point f="32.0000" d="3.000"/>
   <point f="32.1000" d="-3.000"/>
</curve>
<curve name="Octave 1">
   <point f="31.9000" d="-3.000"/>
   <point f="64.0000" d="3.000"/>
   <point f="64.1000" d="-3.000"/>
</curve>
<curve name="Octave 2">
   <point f="63.9000" d="-3.000"/>
   <point f="128.0000" d="3.000"/>
   <point f="128.1000" d="-3.000"/>
</curve>
<curve name="Octave 3">
   <point f="127.9000" d="-3.000"/>
   <point f="256.0000" d="3.000"/>
   <point f="256.1000" d="-3.000"/>
</curve>
<curve name="Octave 4">
   <point f="255.9000" d="-3.000"/>
   <point f="512.0000" d="3.000"/>
   <point f="512.1000" d="-3.000"/>
</curve>
<curve name="Octave 5">
   <point f="511.9000" d="-3.000"/>
   <point f="1024.0000" d="3.000"/>
   <point f="1024.1000" d="-3.000"/>
</curve>
<curve name="Octave 6">
   <point f="1023.9000" d="-3.000"/>
   <point f="2048.0000" d="3.000"/>
   <point f="2048.1000" d="-3.000"/>
</curve>
<curve name="Octave 7">
   <point f="2047.9000" d="-3.000"/>
   <point f="4096.0000" d="3.000"/>
   <point f="4096.1000" d="-3.000"/>
</curve>
<curve name="Octave 8">
   <point f="4095.9000" d="-3.000"/>
   <point f="8192.0000" d="3.000"/>
   <point f="8192.1000" d="-3.000"/>
</curve>
<curve name="Octave 9">
   <point f="8191.9000" d="-3.000"/>
   <point f="16384.0000" d="3.000"/>
   <point f="16384.1000" d="-3.000"/>
</curve>
<curve name="Octave 0-1">
</curve>
<curve name="Octave 1-2">
</curve>
<curve name="Octave 2-3">
</curve>
<curve name="Octave 3-4">
</curve>
<curve name="Octave 4-5">
</curve>
</equalizationeffect>
_______________________________________________
EQKvints.xml :
Code: Select all
<curve name="Kvint 0">
   <point f="48.0000" d="3.000"/>
   <point f="48.1000" d="-3.000"/>
</curve>
<curve name="Kvint 1">
   <point f="47.9000" d="-3.000"/>
   <point f="72.0000" d="3.000"/>
   <point f="72.1000" d="-3.000"/>
</curve>
<curve name="Kvint 2">
   <point f="71.9000" d="-3.000"/>
   <point f="108.0000" d="3.000"/>
   <point f="108.1000" d="-3.000"/>
</curve>
<curve name="Kvint 3">
   <point f="107.9000" d="-3.000"/>
   <point f="162.0000" d="3.000"/>
   <point f="162.1000" d="-3.000"/>
</curve>
<curve name="Kvint 4">
   <point f="161.9000" d="-3.000"/>
   <point f="243.0000" d="3.000"/>
   <point f="243.1000" d="-3.000"/>
</curve>
<curve name="Kvint 5">
   <point f="242.9000" d="-3.000"/>
   <point f="364.5000" d="3.000"/>
   <point f="364.6000" d="-3.000"/>
</curve>
<curve name="Kvint 6">
   <point f="364.4000" d="-3.000"/>
   <point f="546.7500" d="3.000"/>
   <point f="546.8500" d="-3.000"/>
</curve>
<curve name="Kvint 7">
   <point f="546.6500" d="-3.000"/>
   <point f="820.1250" d="3.000"/>
   <point f="820.2250" d="-3.000"/>
</curve>
<curve name="Kvint 8">
   <point f="820.0250" d="-3.000"/>
   <point f="1230.1875" d="3.000"/>
   <point f="1230.2875" d="-3.000"/>
</curve>
<curve name="Kvint 9">
   <point f="1230.0875" d="-3.000"/>
   <point f="1845.2813" d="3.000"/>
   <point f="1845.3812" d="-3.000"/>
</curve>
<curve name="Kvint 10">
   <point f="1845.1813" d="-3.000"/>
   <point f="2767.9219" d="3.000"/>
   <point f="2768.0219" d="-3.000"/>
</curve>
<curve name="Kvint 11">
   <point f="2767.8219" d="-3.000"/>
   <point f="4151.8828" d="3.000"/>
   <point f="4151.9828" d="-3.000"/>
</curve>
<curve name="Kvint 12">
   <point f="4151.7828" d="-3.000"/>
   <point f="6227.8242" d="3.000"/>
   <point f="6227.9242" d="-3.000"/>
</curve>
<curve name="Kvint 13">
   <point f="6227.7242" d="-3.000"/>
   <point f="9341.7363" d="3.000"/>
   <point f="9341.8363" d="-3.000"/>
</curve>
<curve name="Kvint 14">
   <point f="9341.6363" d="-3.000"/>
   <point f="14012.6045" d="3.000"/>
   <point f="14012.7045" d="-3.000"/>
</curve>
<curve name="Kvint_2 0">
   <point f="136.5333" d="3.000"/>
   <point f="136.6333" d="-3.000"/>
</curve>
<curve name="Kvint_2 1">
   <point f="136.4333" d="-3.000"/>
   <point f="582.5422" d="3.000"/>
   <point f="582.6422" d="-3.000"/>
</curve>
<curve name="Kvint_2 2">
   <point f="582.4422" d="-3.000"/>
   <point f="2485.5135" d="3.000"/>
   <point f="2485.6135" d="-3.000"/>
</curve>
<curve name="Kvint_2 3">
   <point f="2485.4135" d="-3.000"/>
   <point f="10604.8575" d="3.000"/>
   <point f="10604.9575" d="-3.000"/>
</curve>
fellegis
Permanent link to this post Posted by fellegis » Thu Mar 31, 2016 7:19 pm
EQ curve generator in javascript, calculate sound resonances in cavity.
http://pvtv.hu/tarolo/out_files/sound/cavity.html
fellegis
Permanent link to this post Posted by Robert J. H. » Fri Apr 01, 2016 4:44 pm
fellegis wrote:EQ curve generator in javascript, calculate sound resonances in cavity.
Thanks, that's a nice project.
Could you extend it to include 3 dimensions along with a material quotient? ;)
Robert J. H.
Operating System: Windows 7
Permanent link to this post Posted by fellegis » Sat Apr 02, 2016 9:27 pm
... to include 3 dimensions ...
2 channel -> one (or more) effect per channel, with different values.
I thinking this, at least two curves to be generated.
fellegis
PreviousNext
Return to Audio Processing
Who is online
Users browsing this forum: No registered users and 7 guests
