Motorola Droid Voice
neex1233
Post by neex1233 » Sun Jun 13, 2010 4:57 pm
How can I make the Motorola Droid startup sound, but my own words, instead of 'DROID'? Thanks! :D
Re: Motorola Droid Voice
Post by Gale Andrews » Sun Jun 13, 2010 5:45 pm
neex1233 wrote:How can I make the Motorola Droid startup sound, but my own words, instead of 'DROID'? Thanks! :D
You will have to drag or record the file for that sound off the Droid smartphone , edit it in Audacity then replace the file on the smartphone. You will need to find out what format and bit rate the file is in, so that it is correct when you load it back. You can look at the file by right-clicking the file > Properties or similar, or drag it into Media Info.
For more help see our Wiki page on Making Ringtones.
This assumes you can physically replace a *system* ringtone with one of your own choosing. If you have questions about that you'll probably be better to ask on the Android Forums.
neex1233
Post by neex1233 » Sun Jun 13, 2010 5:54 pm
I'm not trying to replace the startup sound, I'm just trying to modify it. I don't actually need to change it on the phone (I don't even have a droid). So how would I convert normal voice into droid voice?
whomper
Probationer
Post by whomper » Sun Jun 13, 2010 8:08 pm
first tell us what a droid voice is ! (soundwise - not productwise)
note that if you start with your voice then you can change it some, but the microphone, mike placement, actual room, compression, eq, reverb, and other fx all affect the final sound.
there is no one thing you can do to get that voice.
that said, i have heard it on TV and it is cute once, annoying thereafter. certainly has a touch of reverb in it. probably has some eq and maybe compression and other fx too.
Trebor
Post by Trebor » Sun Jun 13, 2010 9:44 pm
Stereotypical robot voice can be obtained using vocoder and/or comb effects ...
Before-After Stereotypical robot effects#.mp3
(759.18 KiB) Downloaded 337 times
You can get a free comb filter plug-in for Audacity about half way down this list.
A "ring modulator" can be used to make the robot sound gritty, (plug-in attached)
RINGMOD.zip
(1.01 KiB) Downloaded 163 times
Trebor
Post by Trebor » Fri Jun 18, 2010 11:17 am
Having listened to the Motorola "Droiod" it's a bit like the voice synthesis on Speak n Spell (ask your parents :) ) ...
'Droid' said in Speak'n'Spell computer voice.wav
(371.21 KiB) Downloaded 256 times
http://www.analogx.com/contents/downloa ... eeware.htm
