Put audio to different loaded audio's timeline?
moviemixer
Post by moviemixer » Sat Jun 12, 2010 9:56 pm
The question may confuse you as my English isn't my first language. To make things easier I'm putting a link from my flickr pic.
http://www.flickr.com/photos/[email protected]/4693863159/
Basically I'd like to put the bottom ones onto the end of the longer audio sound. I tried cut/copy and paste but it doesn't work at all. How can I do this if possible?
Re: Put audio to different loaded audio's timeline?
Post by steve » Sun Jun 13, 2010 9:26 pm
In Audacity 1.2.6 there are several major limitations to what you can do regarding moving audio between tracks.
If you upgrade to Audacity 1.3.12 you can just select the audio that you want to move, press Ctrl+X to cut it, click on the track where you want to paste it and press Ctrl+V.
moviemixer
Post by moviemixer » Tue Jun 15, 2010 12:05 pm
[quote="stevethefiddle"]In Audacity 1.2.6 there are several major limitations to what you can do regarding moving audio between tracks.
Thank you I didn't realise Audacity's limitations :s I'm such a noob.
Trebor
Post by Trebor » Tue Jun 15, 2010 12:23 pm
One option is to slide the “EVA Stars” forward in time using "time shift" option:
click on the double headed arrow ( flashing below) then you can slide “ EVA Stars” forward in time so it starts when “PROTO MO…” ends.
You can do this “time shift” on Audacity 1.2. or 1.3
See this Youtube video from 2min 30 onwards
