Inserting audacity output into video
alfie
Post by alfie » Mon May 31, 2010 2:48 pm
First post here.
I have recorded an AVI video with rather poor audio that I want to improve.
I extracted the audio using AOA audio extractor and made a great improvement to the audio using Audacity.
What tool can I use to recombine the audio with the video and establish lip sync?
I'm happy to pay within reason for something that is not overkill.
Cheers
whomper
Probationer
Re: Inserting audacity output into video
Post by whomper » Mon May 31, 2010 6:14 pm
i am guessing any quote you could get would be considered "overkill"
if your new file is the same length as the original file in h:m:s:frames
cant you just copy it into the folder it came from and see if it is close enough for govt work when you play them back together?
if you have a clapper at the start of each scene that would help
else you will have to do a lot of work to line things up.
alternatively some heavier duty AV software might be easier to work with then shoehorning an audacity sound edit back into the video.
alfie
Post by alfie » Mon May 31, 2010 6:45 pm
whomper wrote:i am guessing any quote you could get would be considered "overkill"
It was the software I referred to as overkill, not the price. I don't want to buy a complex package with a steep learning curve to do just the one job.
whomper wrote:if your new file is the same length as the original file in h:m:s:frames
You mean playing the audio and video in parallel exactly on cue, and recording the result? Is that really practical?
whomper wrote:alternatively some heavier duty AV software might be easier to work with then shoehorning an audacity sound edit back into the video.
That comes back to the first point. I have a lot of experience with Audacity and have got a good result with the audio file, so I would prefer to stick with it if possible.
whomper
Probationer
Post by whomper » Mon May 31, 2010 9:27 pm
i took yr msg to mean you wanted to hire someone
yes other programs would be pricier than audacity
but perhaps they would be easier enough on your time and blood pressure so as to be worth it
dont know if the suggestion is practical for you
but it would be cheap and not that hard to try
at least it should not harder than trying to line up every scene for lip sync manually -- if you could do that you could try the other way once for no effort
Trebor
Post by Trebor » Tue Jun 01, 2010 5:03 am
A recent thread about video editing freeware ... http://forum.audacityteam.org/viewtopic ... 63&p=82436
Just noticed the original poster of that thread had Windows Movie Maker, with which it is possible to re-dub (replace the video sound track), so they didn't need additional video editing software to change the video sound track.
alfie
Post by alfie » Tue Jun 01, 2010 9:52 am
Thank you Trebor!
I will have a try with that. If it doesn't work I will look at Blazemp that promises to do the job.
Alfie
Trebor
Post by Trebor » Tue Jun 01, 2010 10:01 am
alfie wrote:Thank you Trebor!
Alfie
Blazemp was not mentioned in the thread I suggested.
According to this forum's search engine you are the only person who has written "Blazemp" in a post.
On that thread Stevethefiddle gave this link to a dozen different free video editors.
alfie
Post by alfie » Tue Jun 01, 2010 10:05 am
No, that was another program that I just read about. I will leave it as a backup.
Thanks for your help!
Alfie
